From tub to shower
A few years ago, I replace my cracked tub. I found the manufacturer had run a glob of wires under the tub. I'm not saying your will be like this, but if there is a corner to be cut, the manufacturer will do. You might run into a surprise like I did.
Also, I agree with the above. There is a lot of flex in the walls, especially going down the road. I'm not sure how long they would stick.
