Old 04-08-2018, 11:05 AM   #1
larry2c's Avatar
Going to install window in door - clearance amount?
I bought a 12" X 20" window frame and tinted tempered glass window to install in our TT dor. There is no existing window there and the parts I bought didn't say how much clearance to provide between the outer lip of the frame (see pic for what I'm calling the outer lip) and the cutout. I was just wondering if others who have done this mod have a go by for that clearance. My thought is 1/16" to 1/8" so you have some room to slide the frame & window in and adjust it for straightness.
Thoughts? Thanks!
Name:	window frame.jpg
I just want to be outside!!!
'17 Salem Cruise Lite 210RBXL
'11 F150 5.0
Two shedding mutts
larry2c is offline   Reply With Quote
Old 04-08-2018, 11:08 AM   #2
yes you need a little play to adjust but it also has to overlap good to get a good seal. Measure and mark twice and cut once. What are you cutting with? You may need to cut twice from each side. I had issues with a jig saw blade pulling the fiberglass skin as it went up and down through the door.
Kimber45 is offline   Reply With Quote
Old 04-08-2018, 11:26 AM   #3
bubbles's Avatar
Here's a template with measurements on it. Can make a cardboard template and check.
Old 04-08-2018, 11:34 AM   #4
larry2c's Avatar
Thanks Bubbles, I was surprised my frame didn't come with a template.
Yes, Kimber - I'll be using a jigsaw so I am a bit nervous on how the fiberglass reacts. I'll use a fine pitch blade and put tape on the door to help prevent delamination.
Once I'm finished, I'll post up some pics. I'm really looking forward to the extra light this will let in (maybe the DW won't have to give me grief for opening the door when it's still cold out!)
'11 F150 5.0
Two shedding mutts
Old 04-08-2018, 12:16 PM   #5
bedubya's Avatar
I'm thinking of doing that to my 232RBXL. Where did you get the window kit?
'17 Toyota Tacoma 4x4 TRD Sport
'17 Salem Cruise Lite 232RBXL
'08 Kawasaki Vulcan Classic 1500
Mickey the Rescue Project Schnauzer
Days Camped: 2017-39, 2018-61, 2019-64
bedubya is offline   Reply With Quote
Old 04-08-2018, 02:09 PM   #6
larry2c's Avatar
And now we can see out the door!
I didn't realize until I got the hole cut that I didn't have a before picture but I guess we've all seen a door without a window
Easy mod and we really wanted the extra light in the trailer so this gets a from me and DW. Thanks for the help!
Name:	new window.jpg
ID:	167556   Click image for larger version
Name:	new window 1.jpg
'11 F150 5.0
Two shedding mutts
Old 04-08-2018, 04:08 PM   #7
Thatís a cool mod. I wouldnít mind doing that on our Cedar Creek
spock123 is offline   Reply With Quote
Old 04-08-2018, 06:20 PM   #8
I just bought this kit from Tweetys. It is called "Slim Shade" and cost under $100. The kit contains the tinted glass, inner and outer door trim, and the shade.
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
retiredcamper47 is offline   Reply With Quote
Old 04-08-2018, 06:37 PM   #9
larry2c's Avatar
Ours is a combo - glass from Ross RV Innovations and frame from CW. No shade but DW is going to make a curtain that will use good ole Velcro to hold it in place when required.
'11 F150 5.0
Two shedding mutts
Old 04-08-2018, 08:39 PM   #10
Larry, check Ross R V for his shade that fastens to the screen with magnets when needed. We have his window and shade, works great.
Bigfeet is offline   Reply With Quote
Old 04-08-2018, 09:27 PM   #11
Nice job Larry2c looks like you had it professionally installed.
wcrafter is offline   Reply With Quote
Old 04-09-2018, 03:51 PM   #12
[QUOTE=bedubya;1776377]I'm thinking of doing that to my 232RBXL. Where did you get the window kit?[/QUOT
Dyers rv has the best price. I just ordered one for $79.99. Amazon wanted over $100.
Arkansas Traveler is offline   Reply With Quote
door, mount, window
