Haloview BT7 Installation - Furrion OEM Bracket I
I recently installed the Haloview Byte Tango (BT7) and wanted to share my experience. I couldn’t find any posts that required no modification or removal of the 2024 furrion OEM bracket so I thought this might be helpful to someone else. I used the B-F02 adapter that Haloview sells, and it worked perfectly. This wasn't available on Amazon so I ended up buying both direct. I was surprised the shipping was quick even though it came from overseas.
There was a small hole left in the bracket where the Furrion antenna would go that I noticed could potentially allow water to get behind the camera. While it would drain, likely slowly, I didn’t like the thought of it. To prevent this, I filled the hole with silicone, which worked great to seal it up and keep the back of the camera dry. I included pics of everything as I went through. I wish I would've used white sealant, but I'll get that changed at a later time.
Overall, I'm very satisfied with the setup and the quality of the Haloview system. If anyone has any questions about the installation process of the camera, feel free to ask! Excited to take it on our first trip this weekend and see how it performs on the road.
Edit: Sorry the pictures are sideways, new to this forum and not sure how to rotate them.
