Have you inspected your ducting to be sure it isn't crushed, misrouted or disconnected?
There's plenty of posts about that.
You might want to consider an alternate propane sourced heater like Mr. Buddy.
There are lots of posts about them and you'll get MANY OPINIONS about them being used inside but they really are safe if used correctly.
Just remember, your R/V has relatively thin walls and little insulation. Even R/Vs touted as 4 season are not really. Cold eats up LP and battery quickly. Cold also produces lots of interior moisture, even from just breathing. Always vent the interior regardless of heat source.
