Is the shower enclosure springy enough that you can make it touch the wall with light manual force? If so, I'd consider using a "contact" type adhesive to bond the two together.
The directions vary, but are usually something like "Spread on both surfaces, wait five minutes, then press together." They will instantly grab when pressed together.
Some varieties are flowing liquid, some are paste that comes in a caulking gun cartridge. With the paste type you apply it, immediately press together and release, then wait a few minutes. When you press the second time, the two surfaces instantly bond.
If this were my job, I'd use the paste type.
Larry
