Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 07-22-2017, 01:05 PM   #1
jheacox1's Avatar
Help with replacement shower handles
Hi all,
I need a little help. I want to replace my shower faucet handles with the brushed nickel one to match the rest of the faucets in my camper. Here is a picture of the existing handles. There's no screws/attachment point just for the handles. I'm confused at how to proceed because the housing is so big. Do I have to take off the entire housing then remove the handles? And how can I be sure the new one will fit the existing housing? Should I take the old one with me so the rv parts place can help me find a compatible replacement?
Thank you in advance for any help you can provide.
jheacox1 is offline   Reply With Quote
Old 07-22-2017, 01:11 PM   #2
Originally Posted by jheacox1 View Post
Hi all,
If you pry off the plastic "C" and "H" center pieces I think you will find the screws that hold the handles in place...just like the ones at home.
modemem is offline   Reply With Quote
Old 07-22-2017, 01:17 PM   #3
crunchman12001's Avatar
If you like the brushed nickel, replace the whole faucet, wand and hose for $32.95.
https://www.greydock.com/ultra-fauce...ed-nickel.html
2015 F-250 FX4
Old 07-22-2017, 03:10 PM   #4
jheacox1's Avatar
Sorry I should have been more clear. I don't want to do just the handles but the entire fixture. But it appears I'd have to take the back part off the wall to get the front part, handles, and shower hose connection thing off too. Is that correct?
Old 07-22-2017, 03:13 PM   #5
jheacox1's Avatar
Looks good. I was going to replace the shower wand and hose with the Oxygenics one. Do you know how good that shower wand is from greydock?
Old 07-22-2017, 06:29 PM   #6
Hi,
The faucet brand is a Ultra Faucets. Greydock is just a retailer link I found. I have never heard of this brand but I have used Dura Faucets in the past. I have no idea what faucets are in my current rig, they have no visible tags. They look very similar. (cheap, plastic, non-durable)
I would assume either faucet wand is inferior to an Oxygenics and I have replaced them before my first shower in all my rigs. I suggest you do the same.
These faucets can be found at thousands of places so shop around.
Here is a Ultra Faucet without hose / wand.
https://www.greydock.com/uf08363c-tr...er-faucet.html
Here is a Dura Faucet without a hose / wand.
Designer RV Shower Faucet | Dura Faucet
INSTALL:
Remove the 4 screws on shower wall.
Cut or pry through the silicone if needed to remove the faucet box.
Remove the water lines (take care to secure lines so they don't slide to the side in the wall)
Unscrew the faucet from the faucet box.
Reverse steps for install of new faucet.
Check water connections before putting the box back on wall.
Seal faucet box to wall and faucet to the box with silicone.
Edit: When I replace mine (similar to yours) I will go with a single handle like this.
https://accessories.lazydays.com/dur...SABEgJin_D_BwE
2015 F-250 FX4
Old 07-22-2017, 07:17 PM   #7
jheacox1's Avatar
Hi,
INSTALL:
Thanks. After 3 years of looking at the cheapo shower fixtures combined with the horrible flow from the head it's time for them to go.
Old 07-23-2017, 04:38 PM   #8
CaptnJohn's Avatar
I had the same problem in my Cougar 5er. Often I would bump one knob and freeze or burn. I took that box off and mounted a double lever model attached to a piece of starboard from the marina right on the shower wall. That set it back 4" closer to the wall. When looking this time I wanted a bigger shower and found it in the Montana with a single lever faucet mounted to the shower wall.
2022 Montana 3855 BR
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
Old 07-23-2017, 04:54 PM   #9
Mastertech's Avatar
That's my next upgrade. I've already replaced the shower head and wand with a Oxygenics and really like it so far. Just trying to find the right handle assembly.
1999 Ford F-350 CC LB Dually
2015 Forest River Vengeance 398V
2011 Polaris RZR4
Mastertech is offline   Reply With Quote
Old 07-25-2017, 09:19 PM   #10
I don't remember which one I bought but had to replace ours and the cheapest place I could find was Amazon. They are all made cheap. I did take a drill bit and enlarged the out of the faucet, didn't take much for better water flow.
the.wilsons is offline   Reply With Quote
Old 08-10-2018, 03:31 PM   #11
jheacox1's Avatar
Took me a year but I got the upgrades done. Works fantastic and now matches every other fixture in the camper. Thanks for your help everyone.Click image for larger version
replacement, show, shower
