Old 08-21-2017, 03:54 PM   #261
Weekend Warrior
KyleStout's Avatar
Hey Rich, any progress this month?
KyleStout is offline   Reply With Quote
Old 08-21-2017, 04:17 PM   #262
Yes please give us an update. I am one of many people admiring your work and following along. Jay
Jay2504 is offline   Reply With Quote
Old 08-22-2017, 03:50 AM   #263
rollscanardly's Avatar
Just a little....other projects have a way of coming out of nowhere. Like the fact that I had to remove all the seats, center console, glove box, and anything else that was holding down the carpet liner in my wife's Lexus.
Apparently these vehicles have a common theme where the AC condensate drain hose gets clogged. If that happens, the condensate water will drain into the carpets / carpet liner. You don't notice it until it's too late.
The carpet liner was absolutely soaked especially in the padded areas. You don't wan't mold to form!!
So, I took the carpet liner out, let it dry in the sun for 3 days. then reinstalled everything. NOT FUN!!!
I'll post pics of the camper progress tonight...
Rich
"rolls down one hill, can 'ardly make it up the next..."
1999 21' Wildwood WDF21RK
2006 Dodge Ram 2500, 4x4, Quad cab, 5.9L Cummins, 3.73 gears.
rollscanardly is offline   Reply With Quote
Old 08-22-2017, 06:30 AM   #264
So much for luxury model
2019 Puma XLE 27QBC Toy Hauler
2005 Honda VTX 1300
2002 Goldwing 1800GL CSC Trike
2020 Ram 2500 Crew cab 6.5 bed
Ron & Shirley (Empty Nesters)
rmac04401 is offline   Reply With Quote
Old 08-22-2017, 07:24 PM   #265
Yeah, well....It wasn't a pleasant job, but as far as car problems go, no brand is 100% exempt from it's flaws.
Our last 3 cars have been Lexus'. We buy them used (3 years old) and keep them for quite a few years. Personally, we love them.
This is the first "glitch" we've had to deal with in over 20 years of owning these cars.
This current one is 9 years old with just 83K miles on it, so to me I really can't complain all that much. It was a clogged drain hose....
I've even heard of people spending top dollar on their RV's and having to bring them back to the dealer for repairs soon after driving them off of the lot!! Imagine!! ......
Rich
Old 08-22-2017, 07:29 PM   #266
I've just switched my photo sharing company from Photo Bucket to Imgur. I'm still learning how to navigate this new website (I'm very IT challenged...).
So, I'll post up current update pics soon.
Rich
Old 08-23-2017, 05:19 PM   #267
The original battery cables were mouse-chewed, so we needed new ones. I ordered 2 sets of lugs. When I opened up the Amazon box, only the cables and one set of lugs were in there. Paperwork listed both sets...
So, off to the auto parts store I went, to pick up some ring terminals, because I wanted to finish them up.
My lug crimper...
Re-connected...the circuit breaker that the lugs are attached to is new, too.
Replacing the crappy battery vent tube flange / vent was next...
Before...
After...
...more to come...
Old 08-23-2017, 05:43 PM   #268
Next on the list was replacing the wall outlet for the microwave, located in a closet...
3 new wires were run from the panel to the hot water heater location, as a brand new heater will be installed...
These are some drawer tracks that have to be reinstalled now that all the rotted wood has been replaced. But, they had gotten wet, in the past, and they were rusted, about halfway.
So, I bead-blasted the rust off, and sprayed some cold galvanizing spray on them.
After blasting...
Sprayed...
...more to come...
Old 08-23-2017, 06:03 PM   #269
I also repaired some of the underbelly material that was torn...
..along with some wiring repair...
...trying to keep the water and mice out!
And...if anyone's interested, here are a few shots of the wet carpet adventure...
Glad that's behind me!!
Rich
Old 08-23-2017, 07:36 PM   #270
Impressive. You are one talented & determined fella! Thanks for sharing this with us!
2017 Rockwood Roo 23IKSS
2017 Ford F150
2018 Days Camped: 34
2019 Days Camped: 5, but many more planned!
Maman325 is offline   Reply With Quote
Old 08-23-2017, 07:51 PM   #271
Evereddie's Avatar
Rolls, you are a work of art.
Thanks for taking the time to update us.
There are 10 types of people in the world.
Those that know binary, and those that don't.
2013:31 / 2014:51 / 2015:58 / 2016:37 / 2017:46
2018:16
Total 239
Evereddie is offline   Reply With Quote
Old 08-23-2017, 09:26 PM   #272
Rich:
If you go with the Suburban water heater, some (the ones with an "L" in their model number) have a 12VDC relay that switches on the 110VAC heating element upstream from the usual "outside" heating element switch. The 12VDC relay is switched on/off by a water heater switch that's usually next to the gas water heater switch. This lets you control both gas and electric from inside the trailer. Here's a pic of one way the two switches are made:
If you go with the non-L model, you just plug the heating element into a 110VAC outlet and use the normal outside switch. However, a number of us with these models have wired the 110VAC outlet to be a switched outlet and used a 110VAC switch with a pilot light to control it. So this can also allow you control both gas and electric from inside (although not usually from the same location).
Here's mine:
Here's a switch and a wiring diagram that may help you.
2011 Traverse LT, 3.6L, FWD
Old 08-24-2017, 03:51 AM   #273
I appreciate the kudos...and thank you, rockfordroo, for the insight on the H2O heater. I bought it a long time ago. Is is a Surburban heater. I'll have to check out the model # and go from there.
Rich
Old 10-01-2017, 04:53 PM   #274
A little more progress....
There were these large voids inside the AC framework where the AC could just blow into the rafter area. The PO had taped cardboard over the openings.
I decided to staple some aluminum sheet metal over the openings...
Then, I replaced the metal tape in the shaft that the squirrel cage fan blows into...
Buttoned the AC unit back up...
Next, the wall that was repaired way back when needed a face lift, so stick-on subway tiles were installed...
Before...
After...
More to come...
Old 10-01-2017, 04:56 PM   #275
Impressive, as always!
2017 Ford F150
Old 10-01-2017, 05:18 PM   #276
The next job was one that I wasn't looking forward to, but had to be done....resealing the roof.
I used the 2-step Dicor System. First, the camper was masked off...
The next morning, I used a leaf blower to clean all the debris off of the roof. then, the cleaner / activator was sprayed on and allowed it to sit for a while. Then it got power washed off.
I noticed what appeared to be nail heads protruding through the rubber roof. I figured that I'd better fix this before going through all this work.
I slit the rubber, planning to hammer down the nail head, then Eternabond Tape the slit.
Well, it wasn't a nail head at all...
They were chips of aluminum from drilling . At the factory, they roofed right over these things!!
The black roof makes a mess! This pic was before the washing of the roof...
3 coats later, I now have a white roof!! Yay!!
more to come...
Old 10-01-2017, 05:31 PM   #277
I hadn't looked into the axles to this point. So, today was the day...
Should be enough drum to turn down, but seeing that I'm going to buy complete backing plate assemblies, I may bite the bullet and just get new drums / bearings, too...
Axle tag...AL KO axles...
And lastly, I installed a new vent cover, replaced an existing vent cover, and bought and installed a new A/C shroud....
Well, that's it for now...
Rich
Old 10-01-2017, 05:56 PM   #278
crunchman12001's Avatar
Good job. Thanks for the update!
2015 F-250 FX4
Old 10-01-2017, 06:13 PM   #279
old40ford's Avatar
You are a very talented man, this is a exceptional job you have done. I hope you get many years out of your project camper. Congrats
Retired Auto body teacher
2021 Arctic Wolf 3550 Suite
2019 F-250 Lariat Super Crew 6.2
Having lots of Fun traveling with my wife
old40ford is offline   Reply With Quote
Old 10-01-2017, 06:22 PM   #280
Summer2Go
Summer2Go's Avatar
Insane 1999 Wildwood repair....pic heavy!
I hope the widow almost gave you the old trailer! She probably didn’t have a clue what she was selling!
Summer2Go is offline   Reply With Quote
repair, wildwood
