Old 03-04-2018, 05:52 PM   #381
rollscanardly's Avatar
Any better??
"rolls down one hill, can 'ardly make it up the next..."
1999 21' Wildwood WDF21RK
2006 Dodge Ram 2500, 4x4, Quad cab, 5.9L Cummins, 3.73 gears.
rollscanardly is offline   Reply With Quote
Old 03-04-2018, 05:57 PM   #382
old40ford's Avatar
Originally Posted by rollscanardly View Post
Any better??
still no pictures
Retired Auto body teacher
2017 Puma 255RKS
2019 F-250 Lariat Super Crew 6.2
Having lots of Fun traveling with my wife
old40ford is offline   Reply With Quote
Old 03-04-2018, 06:04 PM   #383
DavidBo's Avatar
I like the fabric selection for the sofa, it's a definite upgrade. It's a good thing you have your lady's input for assistance in this endeavor!
For what it's worth, I use postimages.org to upload pictures. As far as I know it's a legitimate site, not sure if the FRF admin would have any issues.
DavidBo is offline   Reply With Quote
Old 03-04-2018, 06:43 PM   #384
Evereddie's Avatar
I am seeing all pics now. Great work.
There are 10 types of people in the world.
Those that know binary, and those that don't.
2013:31 / 2014:51 / 2015:58 / 2016:37 / 2017:46
2018:16
Total 239
Evereddie is offline   Reply With Quote
Old 03-04-2018, 06:49 PM   #385
I can see them now. As I thought, they are great. Very good looking work as usual. Can't help with the laying of floor. I have only done it in my house. As many cutouts you have, one piece may not be possible.
Dale & Karen
2015 Lacrosse 311RLS
2006 F-250 The 06-6.0
Dwilcox is online now   Reply With Quote
Old 03-04-2018, 07:23 PM   #386
Originally Posted by old40ford View Post
still no pictures
So, some can see them, and some can't??.....
Thanks for the tip! I just joined postimages.
For years I used Photobucket, but then they held people to a $400. ransom.
I switched to Imgur. I still use it, but don't like it.
Thanks, Eddie!
Yeah...I'll probably end up having 3 seams...
Rich
Old 03-04-2018, 09:14 PM   #387
I proceeded to cut out the rest of the flooring...
I also took those dusty rose trim pieces off of the dinette seat frames so that they can be re-upholstered. too...
Here's the layout...
For all of those out there that have installed vinyl sheet flooring, what's the best way to go here, with minimal seams?
I don't think that it's worth trying to make it all in one piece, minus the bathroom. Is it??
...more to come...
I'm pretty ignorant on this subject, but if you google "seams in linoleum floor" and "linoleum transitions and thresholds," I think you'll get some ideas.
Good luck!
2011 Traverse LT, 3.6L, FWD
Old 03-05-2018, 04:34 AM   #388
Thanks for the tip, rockfordroo. I'll do that.
I read the manufacturer's installation instructions. I'm just trying to minimize the seams.
I guess that if done correctly, the amount of seams won't matter much.
We'll see...
Rich
Old 03-05-2018, 06:32 AM   #389
old40ford's Avatar
We'll see...
Rich
I have watched the installer put it down in my home a couple of times and he uses something that looks like super glue on the seams, it is clear and when finished you cannot find the seams or worry about them ever opening up. Maybe just ask at the local carpet shop? Good luck
2017 Puma 255RKS
Old 03-05-2018, 06:40 AM   #390
rmac04401's Avatar
I used vinyl plank pieced when I redid my floor. They stuck down really well and looked much nicer.
2019 Puma XLE 27QBC Toy Hauler
2005 Honda VTX 1300
2012 Ram 2500 Crew cab 6.5 bed
5.7L Hemi, 3:73 Rear
Ron & Shirley (Empty Nesters)
rmac04401 is offline   Reply With Quote
Old 03-05-2018, 07:04 AM   #391
nomad297's Avatar
Toilet removal...
I tried removing the flange, thinking that it was a socket-type fit into a larger pipe, or just went into the tank.
Apparently, it's attached somehow. When I pryed up from under the flange, a piece of it cracked off.
No biggie...I'll just drill and countersink a close by hole to make up for it.
The removed piece of linoleum...
...more to come...
You can easily fix that flange with a $6.00 steel spanner flange.
Bruce
nomad297 is online now   Reply With Quote
Old 03-05-2018, 07:13 AM   #392
old40ford's Avatar
Bruce
Unless it is different than the ones I have worked on in the past, the flange screws in because tanks have to be replaced sometimes. Readily available at any rv dealer
2017 Puma 255RKS
Old 03-05-2018, 08:20 AM   #393
Bruce
I never heard of those before, so I just checked them out. Great concept.
I could make one of those in about 20 minutes.
Thanks for the heads up!
So....they screw in! That makes sense! And here I was trying to pry it up......
Rich
Old 03-05-2018, 12:08 PM   #394
rracer5's Avatar
Hey Rich, nice work....coming along nicely. How about thin (5 mil) vinyl plank flooring? I used the type that have the stick together edges. Looks great & not thick enough to interfere with anything. I did 135 sq. ft. for around $250 from Home Depot. Mine is Allure vinyl plank. You won't need nearly as much. Each box covers around 45 sq ft. at around $35 a box. I then used 1/4 round trim that I found at Lowes that matched the cabinetry to finish the edges.
Aww...nuts....sideways pics!
ID:	164315   Click image for larger version
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 03-05-2018, 03:16 PM   #395
Very nice floor! I was going to buy a type of plank flooring, but got scared off by being told that those floors have a lot of edges, etc., that could possibly lift due to the extreme temperature changes. I live in New England. It gets hot, and cold!
So, I decided to go with vinyl sheet flooring. But....I have heard that others have been successful with plank flooring in their campers.
Where do you mostly "reside"...in a warmer climate? How long ago did you install that floor?
BTW...that looks like a beautiful camper! Mine is like a slum compared to yours...
Rich
Old 03-05-2018, 03:31 PM   #396
rmac04401's Avatar
Insane 1999 Wildwood repair....pic heavy!
Rich. This is what my old camper looked like after doing the floorClick image for larger version
ID:	164348Click image for larger version
These had adhesive on back and never moved. Bought at Lowes. Easy to trim with razor knife. Very durable. Done on a 2000 mallard. About your era of camper.
2005 Honda VTX 1300
Old 03-05-2018, 05:59 PM   #397
Originally Posted by rmac04401 View Post
Rich. This is what my old camper looked like after doing the floorAttachment 164348Attachment 164349
So, it survived the PA winters, no problem?
Did the entire plank stick to the floor, or just the edges, like the Allure planks?
I'd really rather go with plank flooring. It looks way easier to deal with installing smaller pieces rather than a large sheet....
Rich
Old 03-05-2018, 06:10 PM   #398
Here's a pic of the old sofa (again) and a shot of the re-upholstered sofa...
And here's that finished replacement trim piece...
Rich
Old 03-05-2018, 09:09 PM   #399
That looks like some real progress. I didnít have any trouble seeing the pictures. I also agree that the backwards new material looks better. At this rate you might even get to camp early. Jay
Jay2504 is offline   Reply With Quote
Old 03-05-2018, 09:16 PM   #400
rmac04401's Avatar
Rich
The whole piece had adhesive. The pieces were about 3Ē wide. Yes it survive PA winters and summers fine. It also had that wood grain feel. It was all vinyl. Wife really loved it.
2005 Honda VTX 1300
repair, wildwood
