Old 05-06-2018, 02:48 PM   #421
rollscanardly's Avatar
Cleaned up the table legs a bit...
Before, after...(after, before?)...
Table and re-covered dinette cushions, bumperettes, etc. installed...
Started cleaning up the perimeter of the frame, a bit...
Sanded off all the loose rust..
A couple of coats of POR-15 paint...
...more to come...
"rolls down one hill, can 'ardly make it up the next..."
1999 21' Wildwood WDF21RK
2006 Dodge Ram 2500, 4x4, Quad cab, 5.9L Cummins, 3.73 gears.
rollscanardly is offline   Reply With Quote
Old 05-06-2018, 03:06 PM   #422
Bought 5 new GY Endurance tires, 4 new rims, and decided to blast and re-paint an original rim for a spare tire...
Decided to invest in a set of these...
Of course, I had to drill out the holes .032" larger...
New tires/wheels...
So...as you can see, I did not install the original plastic center caps. Reason being is that I bought a set of trim rings/center hubs to dress things up a bit...
I started installing the first one, but suddenly realized that the way that those rings retain themselves is to bite into the fresh paint of the rim right down to the bare steel of the rim.....
So, without even finishing the first ring install, I canned the idea, and will be sending that kit back.
Here's a pic of the scratches..
So, I didn't go back and install the original caps. The lug nuts were all torqued to 120 ft. lbs. and I didn't feel like un-doing everything.....
...more to come...
Old 05-06-2018, 03:08 PM   #423
WOW!!!! By the time your finished it will be WAY better then when new, great work hope you get to enjoy it soon
2017 River Stone Legacy 38mb
2001 Kenworth T2000
2008 Smart on deck
dblr is offline   Reply With Quote
Old 05-06-2018, 03:24 PM   #424
We also installed some new awning material. After reassembling everything, the spring lock latch wasn't working.
So, drilled out the pop rivets again to bring the Right Side spring assembly into the shop to take a look...
The aluminum ratchet gear was worn down...
I turned the wheel around, and it worked pretty good, but for $57.00, I decided to buy a brand new RH side...
Turned around...
Here's a comparison...the new part seems superior to the original part.
The gear is more aggressive, and the locking latch lever is larger...
The original spring diameter...
The new spring diameter...
The new keeper is plastic, but seems way beefier than the original aluminum one. Plus...the new keeper has 2 different spring end tab slots that you can use.
One for the standard-duty application, and another slot for heavy-duty applications.
I used the standard-duty slot.
...more to come...
Old 05-06-2018, 03:43 PM   #425
But, alas...nothing just flows smoothly...
As I went to pop rivet the new spring end cap onto the roller tube, something was preventing the cap from fully seating, on one end..
I read the instructions several times. There are different directions, depending on whether or not your roller tube has a "notch" in it. Mine does not...
So, because of these two little "tab things" in the rim...
I had to add a notch to the roller tube...
I thought about just burring out those 2 little tabs (like the instructions say to), but thought that adding a notch in the tube would be more "professional"...
Anyway...the awning is back on!! It has been off for almost a year...
A few other upgrades...
Stainless steel strap...
A new rear bumper tube wire thing (stainless steel, of course!)...
A few new toys...
Well, I think that's about it for now...
Rich
Old 05-06-2018, 09:53 PM   #426
Thanks for the update Rich. Floor looks great. You will like the higher toilet, at least I like mine. Replaced the house toilets for "Comfort height" sometime back. Comparing you first photos to your latest, you would never guess they are the same 5er. Will be doing the blowmax change out myself soon. You have done an outstanding job.
Dale & Karen
2015 Lacrosse 311RLS
2006 F-250 The 06-6.0
Dwilcox is online now   Reply With Quote
Old 05-07-2018, 03:48 AM   #427
Originally Posted by AZ Pete View Post
impressive work. I have had travel trailers for about 14 years, and keeping the water out along with fixing the shoddy workmanship, they can be a challenge. You are an inspiration.
Thanks, Pete. I must have missed your post when it first came out.....
..so, you know first hand what I'm going through....
Originally Posted by arter368rlbhk View Post
No problem Rich, keep in mind base shoe is taller than it is wide(1/2 x 3/4 )Generally the reason itís used bc it looks less bulky then the 3/4 x 3/4 quarter round or cove molding. Just something to think about
Missed this post, too....I looked up "base shoe molding" after your first post. I didn't really notice the 1/2 x 3/4 stuff..mostly 3/3 x 3/4 stuff. That's what I ended up using.
Well....I ain't re-doing it!.....
Thanks. That was one reason why I took on this project. I figured that my new work would be done with a little more "care" than the factory construction. Maybe it will be a little less prone to some of the common complaints.
It has to be done before July!
I really thought about which toilet to get...original height, or taller height. Science proves that deeper squatting results in a more complete elimination ( research "Squotty Potty").
But, I figured that by the time I'm done with this resto project I'll be to broken down to squat that low.....
Remember...I'm a novice...what's the Blowmax change? (Taller toilet?? ).
Rich
Old 05-07-2018, 09:33 AM   #428
Weekend Warrior
KyleStout's Avatar
where do you think you're at as far as time & money?
Incredible work by the way! FR should give you a free trip to the goshen rally!
KyleStout is offline   Reply With Quote
Old 05-07-2018, 10:23 AM   #429
[QUOTE
Incredible work by the way! FR should give you a free trip to the goshen rally! [/QUOTE]
Not sure he would like that, he might be in bigger demand then the FR techs
2001 Kenworth T2000
2008 Smart on deck
Old 05-07-2018, 10:37 AM   #430
Wow.
johnbryanpeters is offline   Reply With Quote
Old 05-07-2018, 11:14 AM   #431
Money-wise, about $5500.00 total, including the original purchase price.
Time-wise...I don't have a clue. Depending on the hourly rate, I'd say about $120K worth......
[QUOTE
Not sure he would like that, he might be in bigger demand then the FR techs [/QUOTE]
PUH-LEEZE....after this, I don't want to work on another camper, ever again!.....and yet, somehow, I feel as though this one will never be finished.
Originally Posted by johnbryanpeters View Post
Wow.
Thanks, John. You say "wow", and I've been saying "ow!"......
Just the other day while I was sanding the frame using a 4.5" grinder with a flap wheel on it, the wheel hit a bolt and the grinder kicked back and the fast spinning 80 grit wheel hit me right in the chin. Nice abrasion, there...
Rich
Old 05-07-2018, 02:34 PM   #432
Wow - great updates - thanks for keeping us posted!! As cool as it is to see all the updates, I think all of us are looking forward to seeing a picture of you guys camped out, relaxed/reclined in comfy chairs, with your favorite beverages in hand. :-)
2017 Rockwood Roo 23IKSS
2017 Ford F150
2018 Days Camped: 34
2019 Days Camped: 5, but many more planned!
Maman325 is offline   Reply With Quote
Old 05-07-2018, 02:42 PM   #433
Just as confused as you
Scrapper's Avatar
By the time your done you will probably have a sixth sense and know what problems may arise in the future. Great job. Hope to see you enjoying your 5er for other purpose than working on it.
Richard & Jill
Camping since 1989
I deserve hazard pay when camping with my relatives.
Scrapper is online now   Reply With Quote
Old 05-07-2018, 07:17 PM   #434
You guys are awsome...we are also looking forward to reaping the rewards of all this.
And yes...with my favorite beverage in hand!!
Rich
Old 05-09-2018, 10:15 AM   #435
MaineCampingFan's Avatar
Sure have enjoyed following this, hope you enjoy it and thanks for posting!
2015 Freedom Express 246 RKS
2016 Chevrolet Silverado 2500HD Z71 LTZ
Days camping previous years: Not Enough
Days camping in 2020: Still Not Enough
MaineCampingFan is offline   Reply With Quote
Old 05-15-2018, 12:56 PM   #436
Rsgtivr6's Avatar
Started reading this yesterday and just finished to current posts. I am glad I started when I did. I wouldn't have handled the suspense of waiting for updates. Amazing work. I've done facility and equipment maintenance for over 15 years and I know how "fun" that kind of stuff is to work on/replace. Nice to see you take your time with every repair and do it the best you can. That thing should last forever after you are done! Keep up the amazing work, it seems like the FR forums world is watching and waiting. Much respect.
TV: '17 Ram 2500 Big Horn CCSB CTD 4x4
TT: '18 Wolf Pack Limited 325Pack13
Tow Acc: Andersen Ultimate Hitch 2 goose ball mount, AirLift 5000 bags and HD compressor system
Rsgtivr6 is offline   Reply With Quote
Old 05-15-2018, 01:06 PM   #437
Life is great's Avatar
Your project looks amazing and Ill be sure to let you know when i'm ready to have mine redone. Whats your hrly price??
2012 Rockwood Signature Ultra Lite 8312SS riding on Gladiator rubber.
2004 Ford F350 (Black Beauty) CC, SB, 6sp, 6L work horse.
Camped
2016 - 21 nights
2017 - 42 + scheduled....
Life is great is offline   Reply With Quote
Old 05-15-2018, 04:20 PM   #438
Thank you.....and, you're welcome!
I've always had the mindset that "just good enough" doesn't work for me. I'd rather go the extra mile and have more faith in the repairs.
The work near the end of the job is way more enjoyable than the beginning was.
Aw, shucks...I love this stuff so much,....well...just drop it off. I'll do it for free!! ...
Quick update...for the first time ever, I raised and lowered the newly installed awning.
Never having done this before, and having no instructions, I tried it going on guy instinct.
That didn't work out too well...but...thanks to Youtube, I pulled it off!
Also, I didn't have a pull-down hook/rod, so I made a stainless steel one...
Works like a charm!
Rich
Old 05-15-2018, 07:53 PM   #439
That camper just looks great. Inside and outside. Jay
Jay2504 is offline   Reply With Quote
Old 05-18-2018, 10:37 PM   #440
Wow! It looks brand new. Almost time to camp! :-)
2017 Ford F150
repair, wildwood
