Old 04-08-2017, 07:48 PM   #121
rollscanardly's Avatar
I appreciate the kind words....
Rich
"rolls down one hill, can 'ardly make it up the next..."
1999 21' Wildwood WDF21RK
2006 Dodge Ram 2500, 4x4, Quad cab, 5.9L Cummins, 3.73 gears.
rollscanardly is offline   Reply With Quote
Old 04-09-2017, 04:59 PM   #122
Got back up on the roof today. I'm in the process of re-sealing all the roof penetrations, as well as all the corners.
So, today, I'm going to remove the 18 year old original sealant off of 2 roof vents, and re-seal with Eternabond Tape.
Here's the first one...
The old sealant is removed. I'm also going to replace the hex head zip screws with pan head stainless screws. Seems like the Eternabond tape would like these better...
First one done...
Next one...pretty much identical to the first one...
Old sealant removed...
Screws replaced...
Solvent cleaned, new tape,and done...
To play it safe, I decided to run a bead of Dicor self-leveling sealant on the flange side of the tape...
Rich
Old 04-09-2017, 05:10 PM   #123
I figured that before I called it a day, I'd see what was involved with re-sealing the AC unit. So, I took the cover off...
Small bees nest...
More bees nests and debris...
Well, after looking this thing over, I have a couple of choices: right now, there are no leaks from this unit, and it appears that it is a challenge to get waaaaaaay under the base to get new tape or sealant under there...
So, I can leave it as is, or research to see what's involved with removing the entire unit, service the unit while it's out, then attempt to re-seal it.
We'll see....
Has anyone taken off their AC unit?? I'll probably Youtube it...
Rich
Old 04-09-2017, 05:13 PM   #124
crunchman12001's Avatar
Looks nice, good to see you back at it.
When is your first trip?
2015 F-250 FX4
Old 04-09-2017, 05:19 PM   #125
I would have replaced that skimpy little vent fan with a FanTastic vent fan while I was up there.
2011 Traverse LT, 3.6L, FWD
Old 04-09-2017, 05:46 PM   #126
Evereddie's Avatar
x2 on the vent fan.
Who makes your unit? Mine is a Coleman Mach and after taking off the wires it's just 4 long screws/bolts on each corner. Vey easy actually.
There are 10 types of people in the world.
Those that know binary, and those that don't.
2013:31 / 2014:51 / 2015:58 / 2016:37 / 2017:46
2018:16
Total 239
Evereddie is offline   Reply With Quote
Old 04-10-2017, 03:55 AM   #127
First trip may not even be this year. At a minimum, the entire exterior has to be buttoned up. This includes axle work...all new brake backing plates and components, tires, etc. The interior will be re-done, also, but that can wait, if necessary.
I never gave it a second thought. If I had known, I surely would have done so. Maybe I will....
Originally Posted by Evereddie View Post
x2 on the vent fan.
I'd have to check into who makes my unit...you mean very easy to just change out the motor, or to replace the entire vent unit?
Rich
Old 04-10-2017, 12:39 PM   #128
Originally Posted by rollscanardly View Post
Added a layer of 2" Eternabond around the flange, instead of using self-leveling sealant....
Man this whole project is awesome. Where are you getting your Eterabond? Amazon? I'm curious how much you've used. It's not cheap!
Keep us updated!
2017 Cherokee Grey Wolf Limited 26BH
kantonburg is offline   Reply With Quote
Old 04-10-2017, 01:12 PM   #129
Evereddie's Avatar
Rich
Sorry, I was talking about the Air Conditioner. My trailer came with Fantastic Fans so I don't know what it takes to swap out. I do know it's a complete assembly so maybe too late to swap.
2018:16
Total 239
Old 04-11-2017, 03:51 AM   #130
Keep us updated!
Yes....I bought it on Amazon. I bought 2 rolls of 2" wide and 2 rolls of 4" wide (50' long, ea.).
Oh...OK. I'm going to see if I have the gumption to remove the AC unit. I probably will, seeing that I've gone this far.
I could always replace my wimpy bathroom vent fan with one of these...
https://www.amazon.com/Roof-Vent-Vor.../dp/B00APSSPEA
Rich
Old 04-11-2017, 05:43 AM   #131
rmac04401's Avatar
If your going to replace fan I would x2 the fantastic fan. They are quiet and move tons of air.
2019 Puma XLE 27QBC Toy Hauler
2005 Honda VTX 1300
2012 Ram 2500 Crew cab 6.5 bed
5.7L Hemi, 3:73 Rear
Ron & Shirley (Empty Nesters)
rmac04401 is offline   Reply With Quote
Old 04-11-2017, 10:16 AM   #132
One thing that I have always thought of if I replaced my A/C unit is to install a raised "perimeter" around the the opening and mount the A/C on top of that. It would raise the unit off the flat roof and help eliminate leaks. Even 1/2" would make a difference. Just a thought.
cabranch47
2009 Flagstaff HW27SC (NTU 2014)
1999 Ford F150
cabranch47 is offline   Reply With Quote
Old 04-11-2017, 04:08 PM   #133
Yeah...just sux that I'd have to re-do the new sealant job. But, not the end of the world, either. According to the reviews, the Vortex ll moves a lot of air, but it is loud, especially on High speed.
That's a good idea! As it stands now, I really can't get under it to reseal it.
I'd make the riser come all the way out to the perimeter of the unit (or beyond, if feasible), instead of being recessed as it is now.
Rich
Old 04-13-2017, 09:58 AM   #134
VinceU's Avatar
Rich
They come with a foam gasket and indexing bolts. When installed properly will not leak, can be easily removed without the mess.
Old 04-13-2017, 09:12 PM   #135
rracer5's Avatar
X2. Rising it may cause issues trying to button up the interior due to the excessive spacing.
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 04-14-2017, 08:15 AM   #136
AC unit, right?? I saw that gasket while peeking under the AC unit with a flashlight. But, it's a deep enough distance enough under there to NOT be able to inspect it all that well.
So, I have to decide whether or not to pull the AC unit, just to inspect, and possibly replace the foam gasket, or not.
Eventually, when I'm done sealing up all the rooftop penetrations, I'm going to roll on some liquid sealant over the entire roof.
This means that everything has got to be finalized before then.
Good point. I will not increase the height just for that reason.
Rich
Old 04-14-2017, 08:53 AM   #137
VinceU's Avatar
Rich
Just figure over the years hundreds of thousands have been installed, the few that complained of that roof leak was mostly due to improper tightening of the four corner bolts. Purchase gasket and bolts from mfg rep.
Old 04-15-2017, 10:30 AM   #138
Quick question...
Should I just remove this base for the FM antenna, completely? Are these what everyone is still using?
I'm guessing that this type of antenna is outdated.
Located to the right of the black / yellow kneeling pad....
Basically, it's one of these...
I want to know this, before I just go ahead and reseal it...
Thank you.
Rich
Old 04-15-2017, 10:34 AM   #139
VinceU's Avatar
Ha! They still use them new! Just make sure is not grounded whip to base.
Old 04-15-2017, 10:44 AM   #140
Our Jayco had one of those, worked great. Our LaCrosse is just a wire thrown in the back of the cabinet the unit is installed in. Gets some channels, way out in the woods not so much. That's a mod I will do if I miss the radio that much. With the Bluetooth in the unit the DW and kids play their own music.
Dale & Karen
2015 Lacrosse 311RLS
2006 F-250 The 06-6.0
Dwilcox is online now   Reply With Quote
repair, wildwood
