Old 05-26-2024, 06:15 PM   #1
rollscanardly's Avatar
Installed an outdoor shower....
This is our 25 year old camper...a true labor of love....
https://www.forestriverforums.com/fo...vy-125403.html
Being that old, it didn't come with an outdoor shower. we decided that it would be good to have one, so I figured something out..
I tapped into the low point drains, but wanted to be able to remove the apparatus while on the road, and have the low point drains remain intact.
I made up these stainless plates. then bought this set of faucets, which are of excellent quality!
Made up a little spacer bracket for the drain pipes..
Made up this bracket to screw to the frame, permanently..
It goes together like this...
..continued...
"rolls down one hill, can 'ardly make it up the next..."
1999 21' Wildwood WDF21RK
2006 Dodge Ram 2500, 4x4, Quad cab, 5.9L Cummins, 3.73 gears.
rollscanardly is offline   Reply With Quote
Old 05-26-2024, 06:19 PM   #2
Made up a plate to mount the shower head bracket...
Works pretty well!..
It breaks down in about 5 minutes.
Rich
Old 05-26-2024, 06:42 PM   #3
Very nice work!
Kevin
2022 Ibex 19RBM
2022 Ram 2500
antolod is offline   Reply With Quote
Old 05-26-2024, 07:18 PM   #4
isn't the shower curtain a bit transparent?
I'd get kicked out of the campground and probably arrested if I tried that!
BUT.... good idea using the low points like that
Tarpon Springs FL
2022 Salem 24RLXL
Aussieguy is online now   Reply With Quote
Old 05-26-2024, 09:14 PM   #5
I’ve been a fan of yours since you first started posting about this trailer. Once again, what a great job. I wish I had your talent.
2017 F-250 6.7 4x4
2016 W&P CB25
2005 HD RoadKing
2002 Yamaha V Star 1100
Cb25 Joe is offline   Reply With Quote
Old 05-27-2024, 06:56 AM   #6
Thanks for the kudos!
To address Aussieguy's point, there's a back story as to why I did this...
We just bought some land (in the woods) in New Hampshire. After installing a driveway and clearing some of it, we are going to build an off-grid getaway.
During the construction, we will be living in the camper. So, showering outdoors seemed like a good idea. If anyone happens to see us showering, they would be trespassing...
But....I do plan on building a privacy screen setup.
I'm thinking of a pallet, with some socket flanges screwed in at the 4 corners. Then erect a simple, shoulder height, 3-sided structure out of PVC pipe (not glued). Add some curtains, and one of those thick restaurant kitchen rubber mats (with the drain holes in it) to stand on.
Set it about 2 feet away from the camper, and walk in....
Rich
Old 05-27-2024, 10:56 AM   #7
As an aside....last week I de-winterized the camper. There's always a new adventure awaiting.
I was looking in the cabinet under the kitchen sink and discovered a new bait for my mousetraps....SOS Pads!!
That's right, folks...mice seem to love steel wool pads! (and plastic bags, apparently..).
Rich
Old 05-27-2024, 11:35 AM   #8
Great work!
As for the privacy curtain, I've seen pop-up, outdoor shower tents for $20.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 05-27-2024, 11:37 AM   #9
Trailer Park Supervisor
NJKris's Avatar
Rich, you have some mad skills! Real nice upgrade! Seeing all the work you did, makes me happy my unit came with one already installed, I use it frequently, especially washing up pots and pans that don't fit in my sink real well.
Yes, I drink the water!
NJKris is online now   Reply With Quote
Old 05-27-2024, 11:41 AM   #10
NJKris's Avatar
Great work!
I don't even bother. I'll just wear swim trunks. The hand shower still gets in the tight places, lol. But THIS! This is what I need to stand on.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Can't believe it went up 20 bucks in price since I bought it 7 years ago.
Old 05-27-2024, 12:04 PM   #11
Hmmm...good info, folks..thanks!
I didn't even think about a pop-up privacy curtain/tent. That would be a lot easier! (and cheaper)..
NJKris...I take it you don't wear Speedos??!....
Rich
Old 05-27-2024, 01:23 PM   #12
Chuck_S's Avatar
$30 shower tent and a section pallet worked for us during our popup camper adventures. (Outside shower was built into the camper.)
Also, since this was a popup with no bathroom the porta-pottie lived in the tent most of the time. Just pull it out to use the shower.
-- Chuck
Chuck_S is offline   Reply With Quote
Old 05-27-2024, 01:27 PM   #13
RobAmy's Avatar
Very nice
Forest River 2024 E-Pro 15 TB
2021 Jeep Rubicon with 3.0 Diesel
RobAmy is offline   Reply With Quote
Old 05-27-2024, 01:58 PM   #14
NJKris's Avatar
Rich
I'm afraid my current physique will not allow it. I have the portable pop up, a cheapo from Amazon. Rarely use it. If you get one, practice taking it back down. It goes up easy enough, but without a youtube video to take it down, good luck! It's a little tricky just looking at Chinese instructions.
Old 05-27-2024, 05:14 PM   #15
Eh?
I don't see any problem. Never had that issue.
Larry
Larry-NC is offline   Reply With Quote
Old 05-27-2024, 05:16 PM   #16
Rich, gorgeous work. You have great fabrication skills.
Just one question: Instead of using elbows to tap into the low-point drains, did you consider using tees? That way you could put ball-valves or threaded caps on the third leg and retain the drain function.
Larry
Old 05-27-2024, 05:25 PM   #17
Shower setup looks great! For your base, you might want to put the rubber mat on a pallet, to give the water some drainage.
Camped: 2024 (Days/Nights) - 4/3
2023 (D/N) - 34/27, 2022 (D/N) - 41/33, 2021 (D/N) - 37/29, 2020 (D/N): 58/49
TT: 2020 26' Hemisphere 26BHHL
TV: 2020 GMC 2500HD 4x4
glen1971 is offline   Reply With Quote
Old 05-28-2024, 07:01 AM   #18
-- Chuck
Nice...doubles as a bidet?..
Originally Posted by RobAmy View Post
Very nice
Thanks!
That doesn't stop the Rubenesque European guys from wearing them!
Well...this is one of our favorite places...only 1/2 hour away. No problem here, for sure!....
https://dyerwoodscampgrounds.com/wp/
I just want to remove the whole setup when not camping. I don't want to travel with even just the faucets hooked up. It disassembles in just a few minutes.
Thanks....see Post #6.
Rich
Old 05-28-2024, 10:07 AM   #19
Well executed. a nice upgrade.
For remote locations I have had good success with portable solar showers. They are cheap and easily portable to a place like a stand of trees for some privacy even if there are people around. Fill em up, keep em in the sun and take a shower in the late afternoon. they are a pleasant surprise even in cool weather.
ppine is offline   Reply With Quote
Old 05-28-2024, 10:18 AM   #20
Good to know. We just got one but haven't used it yet. Looking forward to it...thanks for the review.
Rich
door, led, show, shower
