Old 05-25-2023, 11:56 AM   #1
Installed Haloview MC7109 on Mini Lite 2109S but antenna is tilted
I just installed a Haloview MC7109 backup camera on my 2023 Rockwood Mini Lite 2109S. But the antenna is tilted to the side because of the Furion eyebrow mount. Has anyone got a work-around for this, or is it okay for the antenna to be tilted? Also, there is a shorter antenna included (three total, one for the monitor in the truck). I'm unclear which antenna to use, but am assuming the longer the better. I am attaching an image showing the camera mounted with tilted antenna, and an image of the shorter antenna (which has a label "camera").
ID:	287645   Click image for larger version
2018 Rockwood HW 277
2023 Rockwood MiniLite 2109S
2017 Ram 1500
MGBussey is offline   Reply With Quote
Old 05-25-2023, 12:06 PM   #2
JimM2109S's Avatar
The true test will be when you are traveling down the highway at speed. Do you have a good image, minimal lag?
When I installed the same camera on my 2109s, I completely removed the Furion mount and mounted the Haloview adapter bracket over top of the Furion gasket, directly to the camper wall.
As to the antenna, my system only had two antennas, one for the camera and one for the monitor.
2022 MiniLite 2109s
2019 Ranger Lariat 4x4
(We're just getting started!)
JimM2109S is offline   Reply With Quote
Old 05-25-2023, 12:22 PM   #3
The antenna on my rear camera is tilted like shown and it has no adverse effect on operation. Maybe if distance was greater than max tow length but then would it matter?
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 05-25-2023, 03:14 PM   #4
Semperfi24's Avatar
I wouldnt think the antenna angle matters. It still has to go through the camper to get to your monitor. It could probably point straight down and it wouldnt make a difference.
_________________________
2023 GMC Sierra 3500 Denali
2020 Cherokee Arctic Wolf 287BH
Semperfi24 is offline   Reply With Quote
Old 05-26-2023, 07:10 PM   #5
SailorSam20500's Avatar
There is no requirement that the antenna be oriented vertically. It will work just as well, and maybe better if horizontal. What is definitely a good plan is to orient both the sending and receiving antennas the same. Signal strength looks like a doughnut, so if both antennas are oriented the same, then the "fat" part of the doughnuts play well together.
The main reason a vertical orientation is used is to get a part of the antenna over the top of anything between the sending and receiving antennas.
FWIW, I have both of my antennas horizontal and get good results. Additionally, I actually hang my receiver upside down. I use some women's hair bungees to attach it to my trucks rear view mirror. Right side up, there wasn't room for the antenna. I set the monitor to flip the display so I see the image correctly. Only issue is the "distance guide" that shows on the display is wrong (it doesn't flip)...
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
SailorSam20500 is offline   Reply With Quote
210, 2109s, antenna, led, lite, mini lite
