Originally Posted by campingbaba
We have a new Cardinal 5 er with a giarad heater . We will be looking to ga back to a tank model water heater . The on demand is just to sensitive. When you try to turn down the temp. The heater shuts off. When rinsing dishes and shut the water off and than turn it back on you get cold water . Never happened with our tank model in our old Wildcat.
Girard has been making On Demand WH for more than a decade. WE had one of the original ones and it was VERY finicky. Sometimes perfect, sometimes it would then scald you followed by sometimes freezing you.
We changed it out for a new Furrion On Demand WH with a digital control that gives the precise temp you set on the control. We set ours at 109 because DW likes her showers hotter than I do. I simply add a bit of cold water to cool it down a bit. We both Love this unit.
Unlike the Truma you do not have to pay for installation. I did it myself in a day and a half. It only took that long because I redid the PEX plumbing to get rid of all the plastic fittings and replace them with brass fittings I know will NEVER fail.
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
