Old 11-03-2016, 07:35 AM   #21
Rigpdx's Avatar
I hope you also checked into SteadyFast system. Great product, great customer service. Seconds to set up once installed and very effective!
good luck!!
2014 Crusader 351 REQ Touring Edition (the Cottage)
2015 GMC Sierra 3500HD SLT (Allison B)
Nights in the Cottage: 2014: 27, 2015: 80 2016: 47,[B]2017:41
2018: Jan= 2, Feb=2, Mar=3, Apr=2, May=7, June=5, July=15, Aug=1,Sept=2,
Running Total:232
Rigpdx is offline   Reply With Quote
Old 11-03-2016, 07:43 AM   #22
Witch Doctor's Avatar
Originally Posted by DanoHB View Post
I am thinking I may only be able to mount 2 in front and 2 in rear, due to the power stabilizers. mine look like the ones in pics below. I am wondering if they sell a cheaper kit then, since i don't need all 6 pieces? I will have to contact them for sure to find out. Just was wondering if anyone else on here had a similar set up?
Oc's post #16 is the correct way to install them you do not need them going the same way as your stabilizers, they sell a foot with an eye to that. You need the 6 point system for them to work correctly 4 up front on the landing gear and two going forward on the rear, otherwise you will not be happy. I had them like the picture showed and changed them to go to the front as OC's then it was stable...
Coachmen M/H
Concord
2018 / 300 DSC
Old 11-03-2016, 08:04 AM   #23
DanoHB's Avatar
No worries. I will just have to order and get the extra parts. Where did you see for that low? Cheapest I saw was $240 so far.
2017.5 Rockwood Ultra Lite 2905WS (all the options)
New TV- 2017 Ram 3500 SRW Sport 4X4
Old TV- 2007 Dodge Ram 1500 Sport (Hemi)- towing vehicle
DanoHB is offline   Reply With Quote
Old 11-03-2016, 08:14 AM   #24
Pretty sure it was AdventureRV.net.
They are listed at $218.99 now but pretty sure they were on sale at $199.
I don't have a TT but my brother recently purchased a 29RKWS and I was looking on his behalf.
Days Camped: '17=30 '18=51 '19=58 '20=98
Old 11-03-2016, 05:31 PM   #25
Originally Posted by OldCoot View Post
I made homemade stabilizers, but mounted them forward to stop front to back motion. The stab jacks do not need side to side stabilizing due to their design IMO. I also reinforced the legs of the stab jacks.
OC Do you have any pics and instructions on how you built yours
2016 Cedar Creek 34RL
2014 Ram 2500 4x4
LindaNTom is offline   Reply With Quote
Old 11-03-2016, 05:53 PM   #26
Originally Posted by Softball Nut View Post
OC Do you have any pics and instructions on how you built yours. Thanks
Just used 1" and 1-1/4" steel tubing and angle iron. I have a vertical and horizontal metal cutting band saws, so it was a pretty simple project. Less than $75 in all 6 of mine when I made them altho I only use 2 across the front and 1 on each side in the back. I also used 3/8" Heim joints on the top to allow for any misalignment and swivels.
ID:	124614   Click image for larger version
Name:	Homemade front stablilizer (Driver side upper).jpg
ID:	124615   Click image for larger version
Name:	Stationary Tube Side View.jpg
ID:	124616   Click image for larger version
Name:	Tubes Ready For Assy on Trailer.jpg
ID:	124617   Click image for larger version
Name:	Rear Anchor.JPG
Old 11-07-2016, 07:44 PM   #27
seidcon's Avatar
I just added the JT Strong arms on my Rockwood 8280 WS last week.
The fronts are really easy and you just need a drill to drill out the holes for the bushings and mounting brackets. Took me around 2 hours for the front and that included getting side tracked with installing all the missing screws that were left off during manufacturing and cleaning and lubrication as I went.
The backs are a little harder and you will need the adapter plates from JT or you can make your own and some angle iron to fabricate the mounting bracket. There isn't a cross brace near to use for mounting. The backs took me around 4 hours and this included fabrication of the adapters, lubrication and re-installing the underside plastic cover.
I found the video from JT very useful but they were using a frame only for there demonstration. The Rockwood is fully enclosed so plan on removing the rear most panel.
Because I had installed a 3" lift to level out the towing, the trailer really shakes a lot without the JT Strong arms. With them it's nice and tight.
Highly recommend them. The JT's are well made.
seidcon is offline   Reply With Quote
Old 11-08-2016, 08:26 AM   #28
Thanks OC, I am going to have to try this mod.
2014 Ram 2500 4x4
