leveling using jacks
I am getting old and hurt my back during leveling/set-up the last three times we went out with our 264 Surveyor.
I recognize the scissors at both ends are for stabilizing the frame ends. The axles support the weight (along with the tongue jack) and transfer the weight to the frame. Boards/spacers are placed under the tires for leveling.
I am thinking of adding 10K capacity jacks to the frame right next to the fore and aft spring shackle brackets on both sides. Since the gvw is about 7500 pounds, a pair of 10K (each) jacks should be able to lift the appropriate side to level the trailer side to side with minor effort. As the tongue is raised/lowered for front/rear level, the front/rear side jacks would have minor adjustments to put similar load on the frame at the front and rear shackle bracket.
By placing the jacks next to the shackle brackets, the location of the main force on the frame is essentially unchanged.
The stabilizers would still be used to steady the ends of the frame.
Has anybody done this either successfully or not?
2018 Surveyor 264RKLE
Retired
Location depends on weather and state plandemic rules.
Most coincidences are carefully planned
