12-09-2021, 05:08 PM
#21
Very cool accessory! According to Amazon, I can get it by 12/14. Hmmmm….
12-09-2021, 06:31 PM
#22
The differences in delivery times might well be one of several factors.
Who is the seller?
Where is it shipped from?
Where do you live?
Who is the carrier?
When I ordered mine it came almist two weeks earlier than originally expected.
With amazon I've actually cancelled orders due to long delays and when checking on them have found other vendors offering quicker deliveries.
Amazon is a strange world.
What I have also found, if ordering something on a Friday and item is not sold/shipped by Amazon, the seller often doesn't enter order until Monday. If they then ship via FedEx or UPS, it can arrive 8-10 days later.
If they ship via USPS it can arrive in 3-5 days.
12-09-2021, 06:47 PM
#23
Who is the seller?
Where do you live?
Who is the carrier?
I really meant
“hmmmm, I might have to place an order”! I agree, though, Amazon is a strange world.
12-11-2021, 05:38 AM
#24
Don
Ordered mine from Amazon and had it in three days. Appears to be a great product.
Don
2005 Cardinal 33CKT
2019 Ram 3500 Limited
2020 Tracker Targa V18 Combo
2014 Voltage 3950 (sold)
12-11-2021, 04:12 PM
#25
Just finished installing the steady stance. Its a very easy DIY project took me 20 min to install (time includes going back and forth to the tools box) and 5 min to correct my error. Here's a hint the screws take a 7/64 allen and the lock nuts 3/8 spin tight or deep socket. Don't put the large washers under the inside nuts or the steady stance won't close all the way when stowing.
Retired Navy
2016 Flagstaff 26 FKWS
12-12-2021, 12:41 PM
#26
I thought this posted early yesterday but it seems my repeater at the ranch can't handle sending pics. This was a very easy DIY project it took about 20 min including getting tools and about 5 min to correct the error I made. Here is a hint the screws take a 7/64 allen wrench and the lock nuts a 3/8 spin tight or deep socket. I put the large washers on the top of the step not required and made the mistake of putting them on the bottom before the lock nut which caused the steady stance to not close all the way use the small washers there. It does the job great thanks TitanMike
Retired Navy
12-12-2021, 12:42 PM
#27
sorry for the double post I thought the first did not go out.
Retired Navy
12-12-2021, 12:56 PM
#28
Thanks for the details on your install. Pictures did not come through on your first post.
Nice job!
XLR Thunderbolt 300X12HP
2014 Ram 3500 DRW
12-13-2021, 03:44 PM
#29
great idea from lippert . ordered Saturday showed up today . Installed but had to do some modifying as these are mainly for lippert brand steps . the steps on my hyperlite 29 hsf apparently are not lippert . Had to cut a strip of metal from under where the steps mount to make it work so they could close . if you don't mount to the outside edge of the step they will not give good support . but mounted to the outer edge they work . my steps were getting wore where the bottom step hits the flange that acts as a stop . the metal was mushrooming and causing play . put these on and solid step now . hope they last for 42 bucks it was worth it and had enough points i got them free
12-13-2021, 07:29 PM
#30
Torklife Glowstep
I recently noticed how the bottom step on my folding steps (3) was sagging more than usual. I'd been losing weight so I knew it wasn't all me.
I was considering a block or two to prop it up while stopped and also wondered what was on the market to help stabilize the step. I found this on Amazon:
https://smile.amazon.com/Lippert-Sta...s%2C220&sr=8-3
I ordered and a couple weeks later it arrived.
Just finished installing it and it's everything they claim. Like how the legs can be adjusted separately to accommodate uneven ground which is the case on my pad.
Don't know if this has been posted before but if not, it's worth looking at if you have folding steps.
We had the same problem with our two step plus the steps were very far apart. We went with the Torklift Glowstep Revolution three step, bolted right in, has adjustable ground stabilizers and the steps are much more comfortable to walk up on. They are a little pricey but very well worth it for us older folks!
12-13-2021, 07:30 PM
#31
Norwood Auto Italia
I gave up with motors and transmission and now hold them up with a race strap and lock them down with a locking pin. I do have a two foot step up when the steps are in their locked position but no longer have to deal with system fails Andrea Chinese manufacturers.
2000 Sportsmobile E350 EB
2006 Renegade/Peterbilt K1854 and T1220
2021 Isata 5 28SS Explorer
12-13-2021, 08:33 PM
#32
Note that these are only for 2 or 3 step units. I recently read on another forum where a guy used clevis pins to mount them to the bottom of the 4th step. Of course they have to be removed but the stability is worth the trouble. I am thinking about using industrial velcro type material so I don't have to mess with clevis pins or bolts.
I am currently using the Camco threaded platform and it provides support but only on one side (And its a PITA as noted several times above).
As mentioned above, the newer "better" steps just will not work for us where we store our rig but it is clearly the primary path for most of the new rigs. I do like the cleaner exterior lines with the hidden steps but it just isn't practical for some of us.
2016 RAM 3500 DRW 4x4 LB LoneStar, w/RDS 33Gal Aux tank, Timbrens, Andersen Ultimate2, SwiftHitch SH04
2018 Chaparral 360IBL w/TST507 TPMS, Lippert GC3 Autolevel, Furrion Backup Cam, Progressive HW50C
2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHUw/Andersen No-Sway
12-13-2021, 10:01 PM
#33
I 'upgraded' from two screw type stabilizers to the 'solid stance' last year.
No comparison.
Setup is less time that it took to do one screw type, and they don't seem to jump around like the screw type did. When stored the stay stored and don't pop out and lock up the steps.
Be sure and measure holes in closed position so they will store properly.
I put in one screw securely and then confirmed the fit before adding the other three.
12-13-2021, 10:46 PM
#34
I have a set to install on the main entrance for now. Before that I was using a scissor's jack from a GTO that worked fine however it was a bit of a pain to deal with. After a year looking at them, I decided to order and they were on back order from every vendor for 4 months. Must be made in China and were sitting in a shipping container off the coast of Comifornia!
12-14-2021, 10:16 AM
#35
Can you post a photo or two of what you described? I am thinking of getting them, as well, and want to avoid the same problem.
12-14-2021, 11:13 AM
#36
looking
Not only in position to deploy but stowing is easy-peasy. Flip up bottom step, retract leg extensions by pulling spring loaded pins, then fold down main leg by pulling pins then securing when down with same pins.
No need to get on hands and knees for either operation as both can be done by flipping step up or down as needed.
I was just looking at these at Lippert. thought I would come here to see if anyone had posted lo and behold here where the answers I needed. I like the flipping the step up and down idea are you still happy with them? This still happy with them goes out to everyone who has installed them
12-14-2021, 11:23 AM
#37
Are mount bolts 1/4"
12-14-2021, 12:31 PM
#38
I had one of those added to my steps and was never satisfied with the stability. I found a step that attaches to the inside floor and swivels out and is sturdy and not allow any movement of the trailer when entering or exiting. They are made by More-ride and I see that they are now installed on FR products.
12-14-2021, 02:33 PM
#39
MORryde if you’re doing a Search.
12-14-2021, 05:21 PM
#40
Probably closer to 3/16"
