Lithium battery questions
Hi all
I just upgraded to (2) Lithium batteries (LiFEpo4) with built in bms. I also upgraded the converter to a Boondocker 1260 CL 60A converter charger.
I am concerned about charging current. The BMS shows that the batteries are pulling 20A constantly. Even after several hours of charging and reaching a voltage of 13.4 Volts, the bms shows 93% charged and is still pulling 20A from the charger.
I thought that the charger (and/or battery bms system) was supposed to go from CC to CV when the battery charge reaches 90%? I.e., it’s supposed to go 20A Constant Current down to a lesser current and Constant voltage.
Here are the specs of each device
Converter charger set to 14.2 volts constant voltage (not multiphase). .
12 volt deep cycle Lifepo4 batteries are brand new.
All cables as short as possible
Most cables are 4 gauge. Some are 2 gauge for short runs.
Voltage at converter output is 14.2 but across batteries is 13.4 (90% charged reading on BMS).
What am I missing? Should I keep charging to 100% and see if it switches to low current mode?
Why, after several hours of charging and reaching 93% charged at 13.4 volts, is this thing still pulling 20 amps?
2018 fR3 30ds. Victron multiplus 2 2x120 24 volt lifepo4
