Old 09-24-2023, 08:58 PM   #21
Originally Posted by Robsteeler66 View Post
I’ll have to bring a footstool too, because my wife can’t reach it. [emoji23] So the vent cover is screwed over the vent? Do you remember which cover you went with, and do you have to remove the current lid? I know it’s a lot, but we’ve never had an RV. I’ve never even camped in one, just a tent.
My Wife couldn't reach the one in the bath and the one over the bed was difficult in a different way.
We had a fantastic fan in our Class B and when we got the TT, knew we would upgrade from tiny, noisy, ineffective fan in the bath.
Went with a pair of Maxair deluxe, with the remote. No step ladders involved, or other contortions and no worries about them being open in the rain.
By the time you buy a cheaper fan and a rain cover, you're probably not that far in cost from a Mazair deluxe.
2024 Surveyor 252RBLE
2023 F150 Powerboost 7.2KW 4x4 1658PL with a WeighSafe WDH
DJ252 is offline   Reply With Quote
Old 09-24-2023, 09:00 PM   #22
I have these over my vents.
https://www.amazon.com/Maxxair-503-1...s%2C167&sr=8-5
allows me to have them open in weather.
Marc in sunny California
2013 Crusader 260 RLD
2012 RAM 2500 Laramie CTD and 4:10
mmartin_tdc is offline   Reply With Quote
Old 09-24-2023, 09:03 PM   #23
I’m going to show my wife all the alternatives and let her decide. We’ve already spent a butt load of money after we got this thing less than a month ago. I still have things I want and even a couple I need.
Robsteeler66 is offline   Reply With Quote
Old 09-24-2023, 09:07 PM   #24
Little 4” fan replacement
Would this one work?
MAXXAIR 00-933066 Original Vent Cover-White https://a.co/d/hOB1Ys8
That is the cover we have.
For the Hengs fan, your remove the factory screen, remove the factory fan motor and install the Hengs fan. Very easy. I did have to trim about 3/4” off the factory bezel and quite frankly that was the most timely part of the install.
2022 Cherokee Wolf Pup 18TO
2022 Dodge Ram 2500 6.4l Bighorn
Ballistic is offline   Reply With Quote
Old 09-24-2023, 10:48 PM   #25
Attachment 293191
This is my fan.
We have one of those in our trailer. It is worthless except to make noise. I'll replace it with a 4-speed reversible fan, i.e. Max Air fan etc next spring. $138 or so.
Bob
Bob K4TAX is offline   Reply With Quote
Old 09-25-2023, 07:52 AM   #26
Bill and Gail's Avatar
It's easier to install the Hengs fan. You don't have to remove and install from on the roof. Then, just install the Maxxair fan cover. This way, you don't have to remove the caulking and reseal it.
Bill and Gail
2016 Sunseeker 3010DS
V10 6 speed transmission
2017 Ford Fiesta toad
Bill and Gail is offline   Reply With Quote
Old 09-25-2023, 08:32 AM   #27
Just to clarify for the OP who questioned this... to install the Hengs FAN you do not need to get on the roof. The fan assembly installs from inside. A slight modification of the trim bezel may be required.
To install the Maxxair COVER you DO need to get on the roof. It installs over the existing vent cover (no you do not remove the original vent lid or housing) with brackets that screw to the existing vent's metal housing and then the cover bolts to that. The existing vent lid opens inside the Maxxair cover for weather protection.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=101
Old 09-30-2023, 09:16 AM   #28
Okay. I was going to go with the Hengs fan, but I think I’m going with this one. It’s a little bigger, and the blades are translucent.
Upgrade Kit Rv Trailer Camper Van Roof Vent Fan Motor Replacement, Compatible with Heng's, Ventline https://a.co/d/6ASfkn4
Old 10-01-2023, 04:26 PM   #29
And here it is in place. Click image for larger version
Old 10-01-2023, 06:37 PM   #30
Wodstock's Avatar
Put a cover on your existing vent.
Exactly this. Hengs and cover. Figure out which fan is in there and get the cover for that fan. The uv on the fan covers is brutal and the covers on the factory default fan is know to crack or open and then youll be addressing more issues possibly.
Wodstock is offline   Reply With Quote
Old 10-01-2023, 06:43 PM   #31
Wodstock's Avatar
Looks great! I would still recommend a cover. It may prevent it from opening as wide but added longetivity.
Old 10-01-2023, 07:43 PM   #32
I just installed the fan in the picture. It’s the rvlovent fan. I’ll probably put a cover over the top in the spring.
Old 10-01-2023, 07:58 PM   #33
Kanadian Kamper
kenandterry's Avatar
And here it is in place. Attachment 293571
Ok…..3 speed in or out. So how does the air flow volume compare to your original wimpy plastic fan, and how is the noise level across the 3 speeds?
Ken and Terry
2018 Sunseeker 2430S-CD, nicely modified and carried by a 2017 Ford E450 Sport with 6 speed Triton V-10
kenandterry is online now   Reply With Quote
Old 10-01-2023, 09:03 PM   #34
Sounds pretty good. Not too much louder and moves way more air.
Old 10-01-2023, 09:04 PM   #35
Luckily it came with screws, because the factory fan was just sitting up there with no screws. [emoji23]
Old 10-01-2023, 09:06 PM   #36
My only wish was that the wires were in a better location or came out on the same side as factory because you can see them. Not a huge deal but it would have been nice.
fan, replacement
