10-26-2020, 12:56 PM
Max Air Fan reversal
Howdy FR Crew! We have the dual Max Air fans in our Rockwood Mini-Lite. They are not the upgraded model that can reverse. I want to have the fan over the bed to blow down, not up, and the one in the bathroom to suck the air out. Hence, if I can reverse the fan in the bedroom, I can help move a lot of air on stuffy warm days. I read that this can be done by swapping the wires on the motor. Anyone done this?
10-26-2020, 01:20 PM
I've not done it on your particular model but on some older crank up vent motors I did.
DC motors will certainly reverse if the leads are swapped. Look at power window motors, awning motors, slide motors, etc... all reversed by swapping the leads. (done with a switch in those cases)
One thing to keep in mind... the roof of a R/V sitting in the sun can get awfully hot... are you sure you want to suck that hot air IN the vent? You'd be better off opening a window and let BOTH ceiling fans pull air INTO the R/V from below.
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=64
10-26-2020, 03:49 PM
2019 Coachmen Freedom Express 281RLDSLE
2018 2500 HD Silverado
Equal-i-zer Hitch E4
10-26-2020, 04:10 PM
Grab a DPDT rocker switch on Ebay.
About 6 bucks incl shipping.
You'd need to cut a rectangular hole in your trim.
A nice DIY upgrade and not that hard. You'll need some push on connectors as well. Those can be had from Lowes or Home Debit.
https://www.ebay.com/itm/DPDT-20-AMP...EAAOSww41e6M7c
Be SURE you get a maintained type switch and not momentary!
(Momentary work great for slides and awnings but not so much on fans!)
Peace!
Dan & Rita D
10-27-2020, 11:34 AM
Thank you
Awesome - I can always count on the FR Team to come through. I appreciate your suggestions. Based on the recommendations posted, I found a YouTube how-to video as well. Thanks also for the switch link - that's helpful to assure I have the right one for this project.
10-27-2020, 11:42 AM
Here's a link to a diagram showing how to wire a motor reversing switch.
https://www.rollertrol.com/DC-motor-...switch-diagram
Good luck!
This is typically a one beer project!
Peace!
Dan & Rita D
10-27-2020, 02:35 PM
In-and-out
I've done the reversing trick on fans, too.
5-picker, here is the use-case for one intake fan and one exhaust fan. Suppose you are out hiking or at the pool all day on a nice hot day. You come back to the trailer after it's started to cool down. You open the trailer to get away from the vicious mosquitoes and get hit with a blast of hot air. You duck inside and close the door. The quickest way to do a complete air exchange is to run one fan on intake and the other on exhaust. The air streaming through the trailer minimizes the dead spots.
Larry
10-27-2020, 02:51 PM
Crappy Smell
Another thing to keep in mind is that some fans are located next to the black water tank vent.
10-27-2020, 03:03 PM
Oh... I agree, there is a time and place for one intake and one exhausting... we do it a lot!... it just isn't in the middle of a stuffy warm day as the OP eluded to wanting to use theirs where the roof air temperature is many degrees OVER ambient.
10-27-2020, 04:14 PM
Clarification
Thanks again for all the valuable insight. Just for a quick clarification, we generally use the fans at night to help move air while sleeping. For the most part, if the weather is good, we are outside exploring, or if I can find a trout stream to try my luck at attracting a hungry fish to a dry-fly (now that's paradise!).
10-27-2020, 06:39 PM
10-27-2020, 08:32 PM
Reverse fan
Make sure the location of your sewer vent. I know that one of my 3 max air fans is located within 3 ft of the sewer vent on the roof
2018 isata 3 FW
2014 Jeep JK Rubicon
10-28-2020, 07:04 AM
I added a 12v fan that way I can also move the direction so it blows right on us. 3 speed Marine grade spliced it into the 12 v wire
Don & Liz B.
Pink Retired Greyhound
2016 GTS 2800QSF
10-28-2020, 07:17 AM
I like that idea! I have an -old- 12v oscillating fan we used to use when we were tent camping before we moved to trailers. It's from K-mart and probably 25+ years old. It has a large plastic clamp to clamp to the edge of a shelf or table top but we don't really have a convenient shelf in range of the bed. I think I need a fan like yours!
Peace!
Dan & Rita D
