Old 04-23-2016, 06:35 PM   #1
PHS79's Avatar
Mounting lights to awning rail??
I bought some RGB LED strip lights to mount to the awning the lights that I bought are IP66 rated (basically they are fully encased in silicone). Today I tried to put them up but the 3M tape that I had from a previous project Two Rolls 3M Acrylic Foam Adhesive Automotive Industrial Double Sided Tape | eBay would not stick to the back of the lights.
Should I tape an aluminum channel to the rail and put the lights inside of it (for an extra $85)? I would rather just mount the lights to the rail with tape but I am not sure what will stick to the back of these lights, any recommendations??
TT-2013 Passport 3220BH
TV-2004 F150 FX4, not exactly stock...
nights camped:
with 2001 Kodiak K215: 2010-10, 2011-12
with 2012 Grey Wolf 26BH: 2012-19, 2013-24, 2014-11, 2015-6
with 2013 Passport: 2015-13, 2016-15 booked
PHS79 is offline   Reply With Quote
Old 04-23-2016, 06:46 PM   #2
World Wide Wanderer
wahoonc's Avatar
Try using some silicone caulking, put dabs on the rail and bed the lights into it. The other option is to buy some tape rated for the silicone.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 04-23-2016, 06:49 PM   #3
Left Coast
I used the alum channel.....screwed into rail and sealed screws....no mess to clean up when they burn out and changing led strips
Old 04-23-2016, 06:52 PM   #4
crunchman12001's Avatar
Did you clean the light strip with alcohol?
Edit: wahoonc, never new about silcone tape, thanks for learning me something new today.
PHS79, try that if alcohol wipe does not work. My LED's all ready had Chinese sticky tape applied. IP65's so my 3M tape worked.
2015 F-250 FX4
Old 04-23-2016, 06:58 PM   #5
Left Coast
I bought the clear channel cover for the channel, cut it into 12" lengths, spread those out, inserted strip, done....leave the tape on the strip....it's an insulator..
Old 04-23-2016, 07:03 PM   #6
Sorry bob caldwell, alcohol cleaning was for OP.
2015 F-250 FX4
Old 04-23-2016, 07:15 PM   #7
PHS79's Avatar
Good point about replacement in the future! What size and style of screws did you use? Also what channel? I found this on amazon, http://www.amazon.com/LEDwholesalers...+strip+channel
I first tried without the alcohol, then with wiping it down. Unfortunately both had the same result.
I did not know anything about the silicone tape either, but I will look into it.
nights camped:
Old 04-23-2016, 07:22 PM   #8
Left Coast
What you found is what I used.....think I used #4 x1/2" sheet metal screws, I went with the ones that require a countersink...
Old 04-24-2016, 09:58 PM   #9
Swift2
Swift 2's Avatar
I usually put contact cement on most serfaces before I put the LED strips down. Haven't tryed it outside yet.
Swift 2 is offline   Reply With Quote
awning, light, mount
