My first mod is complete on the 183. I don't know if anyone has done anything similar or not but We really did not want the poo poo tank in the car or rolling around in side the TT. So I decided to make a holder for it. Nothing fancy but a couple L brackets, U bolt clamps, and about 45 minutes. I ended up sliding the spare over to the right about 8 inches and then mounted the brackets. Had to drill a few new holes in the brackets cause the holes were a little off and small but a little time and it was done. I think the only thing left to do is get some eye bolts for the ratchet straps. The hooks do not really sit in the pre drilled holes well but that is a quick easy fix and it will be good to go. I'm happy with the end result. Now I just have to remember to remove the tank before I lower the bunk [emoji2].
Tim
