Old 04-14-2013, 06:02 PM   #1061
LKicklight's Avatar
Controllers
If I have the IR type can I use the RF type without a problem of getting the lights to function?
2500HD 6.0 Gas/Ext. Cab
2011 Crusader 270RET
2003 Sunnybrook T/T 30FIS
2012 Jeep Compass Limited
1985 S-10 One Owner:
LKicklight is offline   Reply With Quote
Old 04-14-2013, 06:20 PM   #1062
Herk7769's Avatar
The controllers are designed to work with all the common LED strip types.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 04-17-2013, 09:16 PM   #1063
TURBS's Avatar
Another upside down camper !
I love these new models !
Old 04-17-2013, 09:24 PM   #1064
jtstromsburg's Avatar
That way the water drains out better....
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 04-17-2013, 09:26 PM   #1065
Tonk Mom's Avatar
And the roof won't leak.
Jill
Jill and Ed and the kitties
1998 Coachmen Leprechaun 31Q
Tonk Mom is offline   Reply With Quote
Old 04-17-2013, 09:31 PM   #1066
LKicklight's Avatar
Installation Complete
Installation finally completed...Tapped into the DC wiring at the outside bug light next to the entry door....removed all the inside stuff from the light fixture, replace it with the controller and the antenna wire...Drilled a small hole in the bottom of the plastic, ran the antenna head out and caulked the hole..Ran the power cable out through another hole on the side of the light fixture up to the light string..everything is caulked up well...with on a short piece of wire leading to the light string...not noticable at all...the antenna lead was attached to the camper side with a tie wrap and a stick pad for holding wires in place...pictures to follow...
Everything works up to forty feet away, in the dark of course...looks spookey behind the ADCO Cover that is still on the coach...
Old 04-17-2013, 09:37 PM   #1067
Originally Posted by Stanleyg View Post
I also mounted led's inside my pantry to come on when the door is opened and off when closed...
Put led ribbon lights in our pantry with a microswitch on the door and earned some BIG points with TOWTA!
ID:	28289   Click image for larger version
ID:	28290   Click image for larger version
Old 04-17-2013, 10:09 PM   #1068
spierce617's Avatar
Installation finally completed...Tapped into the DC wiring at the outside bug light next to the entry door....removed all the inside stuff from the light fixture, replace it with the controller and the antenna wire...Drilled a small hole in the bottom of the plastic, ran the antenna head out and caulked the hole..Ran the power cable out through another hole on the side of the light fixture up to the light string..everything is caulked up well...with on a short piece of wire leading to the light string...not noticeable at all...the antenna lead was attached to the camper side with a tie wrap and a stick pad for holding wires in place...pictures to follow...
Everything works up to forty feet away, in the dark of course...looks spooky behind the ADCO Cover that is still on the coach...
This sounds exactly of the install that I am thinking of doing. Would you be able to post some detailed install pictures?
2005 Winnebago Adventurer 38R
Workhorse 8.1/Allison Transmission
Old 2005 Forest River Cherokee Lite 28A
spierce617 is offline   Reply With Quote
Old 04-18-2013, 07:58 AM   #1069
Tonk Mom's Avatar
Awesome, Old Coot, who/what is TOWTA?
Jill
Old 04-18-2013, 08:02 AM   #1070
TURBS's Avatar
The One With The Authority! his dw
Old 04-18-2013, 08:14 AM   #1071
I think I'm going to put that on my rear tire cover.
grayfox is offline   Reply With Quote
Old 04-18-2013, 08:31 AM   #1072
Tonk Mom's Avatar
What is dw?
Jill
Old 04-18-2013, 08:33 AM   #1073
Always Learning
Dear/Darling/Dang/D}%%# wife
Old 04-18-2013, 08:33 AM   #1074
DW dear wife DH dear husband
Old 04-18-2013, 08:34 AM   #1075
I like you definition better
Old 04-18-2013, 08:36 AM   #1076
Tonk Mom's Avatar
Ah. Why not just say wife or husband then? I just don't get these acronyms.
Jill
Old 04-18-2013, 08:37 AM   #1077
TURBS's Avatar
Faster and easier ?
Old 04-18-2013, 08:46 AM   #1078
Always Learning
Habit, mostly.
DD - daughter
DS - son
AWESOME - Me/Doug
MIL - monster in law (err... mother)
FIL - father
TURBS - emotional issues guy
TV - tow vehicle or television depending on context
TT - travel trailer
FW - fifth wheel or freshwater depending on context
BW - black water
GW - gray water
I type 90% of my posts form my phone. It's just more convenient.
Old 04-18-2013, 08:56 AM   #1079
Tonk Mom's Avatar
What is a TOAD?
Jill
Old 04-18-2013, 08:57 AM   #1080
TURBS's Avatar
A car "towed" behind a camper !
awning, led pad
