Old 05-10-2012, 09:34 PM   #1
wagon52's Avatar
My solution to awning lights
Bought these LED strip lights off eBay. http://cgi.ebay.com/ws/eBayISAPI.dll...#ht_3819wt_922
Wasn't sure how I was going to mount them. At first I thought I would put a Velcro strip on the awning tube and another on the light strip. That didn't work since the Velcro wouldn't stick to the LED strip. After looking at the strip lights I thought It looked like they would fit in the rail on the awning. Well they did! And better yet, they will roll up right in the awning. Take a look, I can get some closer pictures of them in the daylight tomorrow.
ID:	13572   Click image for larger version
ID:	13573   Click image for larger version
ID:	13574   Click image for larger version
ID:	13575   Click image for larger version
2012 Rockwood Signature Ultra Lite 8312SS
2008 Rockwood Roo 21SS (History)
1981 Starcraft Galaxy 2108 (its gone)
1999 Dodge Durango (Retired TT)
2006 Dodge Ram 3500 Quad Cab 4x4
wagon52 is offline   Reply With Quote
Old 05-10-2012, 10:11 PM   #2
I have a manual pull down awning. Are you saying these lights will fit in the same channel the center strap fits in? Just wondering how this would work if you were to leave the lights in and roll them up inside. (Where does the strap fit in)
kjoh75 is offline   Reply With Quote
Old 05-10-2012, 10:18 PM   #3
wagon52's Avatar
I have a power awning, so there isn't a strap. In your case you would have to take them out before rolling up the awning. Yes it fits in that channel. It slips in very easily so it wouldn't be a big deal to do.
Old 05-10-2012, 10:18 PM   #4
Sorry, let me add this. If the lights were to sit inside that channel the strap would stay to the far left or right when rolling it up.
Or maybe you have an electric awning with no strap??? Is this the case?
Old 05-10-2012, 10:20 PM   #5
Wagon 52
Sorry I didn't see your post prior to my response.
Old 05-11-2012, 05:59 AM   #6
miatared's Avatar
I also installed a similar LED light strip, but mine has double sided tape on it.
I simply stuck it on the metal roller, between the awning and the slot, since I have a manual awning it needed to stay clear. I leave it there, the awning rolls up as usual.
I have a 13ft awning and the strip was 16ft, so I cut it (can be cut to length every 4 inches or so). The multi coloured effects are fabulous, the remote blows people away.
Well, let me tell you, we were the talk of the campground last weekend , never had so many visitors .
I just ordered 6 for friends (so many people are scared of buying off eBay...) Will help them with the install.
Highly recommended mod.
Denis & Diane
* Happy Campers *
miatared is offline   Reply With Quote
Old 05-11-2012, 06:37 AM   #7
TURBS's Avatar
Ordered my set!
Did you pimp your awning with a remote yet? http://www.forestriverforums.com/for...mod-20827.html
Old 05-11-2012, 06:43 AM   #8
TTNewbees's Avatar
Ordered as well, thanks for the link.
Mike
2012 Lacrosse 303RK
2012 F250 6.7 diesel
TTNewbees is offline   Reply With Quote
Old 05-11-2012, 06:59 AM   #9
Now, if they just make a circular contact so you didn't have to disconnect the wires.
Old 05-11-2012, 07:53 AM   #10
wagon52's Avatar
Originally Posted by f1100turbo
Ordered my set!
No I haven't done that yet. Haven't gotten enough nerve up to tackle it. I'm a bit electrically challenged.
Old 05-11-2012, 07:57 AM   #11
wagon52's Avatar
Here are a few close ups of the lights in the track. It's very snug and I don't think I will have any worry of it falling out. The only thing I've found is that after its been rolled up in the awning I had to pull the strip out a little bit. Also I don't think the little plugs will do any damage to the awning.
ID:	13586   Click image for larger version
ID:	13587   Click image for larger version
Old 05-11-2012, 08:05 AM   #12
Herk7769's Avatar
My strip lights are on the way here. I got the ones with the sticky tape and will stick them to the wall; just under the awning rail.
Film at Eleven...
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 05-11-2012, 08:13 AM   #13
TURBS's Avatar
Smile
Film at Eleven...
That's where I'm putting mine on the wall under where the awning rolls up.
so when awning is rolled up they are protected/hidden
Old 05-11-2012, 08:19 AM   #14
Silly question, are you just plugging this into an outside outlet for power?
merlin66043 is offline   Reply With Quote
Old 05-11-2012, 08:28 AM   #15
Can you connect 2 strands together? Have camper at a seasonal site but would be great along the bottom of the camper
jmswms is offline   Reply With Quote
Old 05-11-2012, 08:40 AM   #16
wagon52's Avatar
Yes it came with the 110v adapter and I use an extension cord. Yes you can string multiple strips together.
Old 05-11-2012, 08:41 AM   #17
Herk7769's Avatar
Many lengths are available on eBay and they can be cut shorter.
They are 12 volt DC and come with a wall wart (transformer).
While it is certainly easier to run an extension cord and use the wall wart; my plan is to investigate using the same hole the awning motor wires use to route switched DC to the awning arm for use by the LEDs.
If that won't work; my backup is a small hole into a storage cabinet above the fridge (the awning arm is right next to it).
Old 05-11-2012, 09:02 AM   #18
Love these lights; what a great idea. How long did it take to get them? We are moving towards the end of this month (Richmond to Chesapeake) and want to be sure not to miss them.
Don and Laura + Roo
Chesapeake, VA
VAlover is offline   Reply With Quote
Old 05-11-2012, 09:46 AM   #19
TURBS's Avatar
Minimum is ten days I think
Old 05-11-2012, 10:08 AM   #20
Herk7769's Avatar
Ordered mine on the 26th and still waiting.
They should come in any day.
awning, led pad
