Old 01-26-2013, 01:57 PM   #641
TURBS's Avatar
I think herk7769 had the best mounting option.
Turbs
Old 01-26-2013, 02:35 PM   #642
Herk7769's Avatar
Turbs
If you are careful to place the strip along the edge, there is enough room for two strips of LED lights in the mounting rib against the camper wall. I need to get a photo of the double strip mod.
ID:	23480   Click image for larger version
ID:	23481   Click image for larger version
ID:	23482   Click image for larger version
ID:	23483   Click image for larger version
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 01-26-2013, 07:46 PM   #643
Owner/Operator
RodeoGeorge's Avatar
After just reading through all 642 posts, I went looking for a source. Using Herk's link, I then scrolled through the 16 pages of Star-doo listings and found the 5 Meter, 300 LED, 5050 Waterproof SMD LEDs with the 44 Key Controller for $25.27.
5M 300 LED 5050 Waterproof RGB SMD Flexible Lamp Strip Light 44 Key IR Remote | eBay
Herk, do these look like the ones that you used, WITH the 44 Key Controller?
Thought I'd check to see if I missed something.
RodeoGeorge
RodeoGeorge is offline   Reply With Quote
Old 01-26-2013, 07:48 PM   #644
TURBS's Avatar
Bad link ↑↑↑↑↑↑↑
Old 01-26-2013, 07:56 PM   #645
Owner/Operator
Sorry about the link. Forgot that I copied something else after the link. I corrected the post, and also here's the link.
RodeoGeorge
Old 01-26-2013, 07:59 PM   #646
Coops1's Avatar
Bad link ↑↑↑↑↑↑↑
It works for me
26WRB - V-Lite
Denali HD LML
Coops1 is offline   Reply With Quote
Old 01-26-2013, 08:08 PM   #647
TURBS's Avatar
RodeoGeorge
Works now!
Old 01-26-2013, 08:13 PM   #648
Herk7769's Avatar
I used the smaller controller initially and added the larger controller later.
16 4ft IP65 5050 SMD RGB 5M Waterproof 300 LED Strip Lights 24 Key IR Remote | eBay
But the one you linked to has the same LEDs and the larger controller I am using now.
Old 01-27-2013, 02:15 PM   #649
PHS79's Avatar
I just ordered the lights that wa3pnt linked. I may have found another solution for mounting the controller, there is a wall inside the camper where the rear awning support is located. And that wall buts up to the rear storage compartment, so I think I can work with that area and then run the wires and sensor wire out like herk did.
TT-2013 Passport 3220BH
TV-2004 F150 FX4, not exactly stock...
nights camped:
with 2001 Kodiak K215: 2010-10, 2011-12
with 2012 Grey Wolf 26BH: 2012-19, 2013-24, 2014-11, 2015-6
with 2013 Passport: 2015-13, 2016-15 booked
PHS79 is offline   Reply With Quote
Old 01-27-2013, 02:42 PM   #650
Owner/Operator
Ordered the ones I linked above. Estimated delivery 14 Feb to 3 March.
But, I'm still at least that far out on delivery of the new 8289WS, so the timing should work out.
RodeoGeorge
Old 01-27-2013, 02:47 PM   #651
TURBS's Avatar
RodeoGeorge
Everything is falling into place!
Old 01-27-2013, 11:21 PM   #652
SYE
SYE's Avatar
Herk, I have a question, and because my wife is the pickiest one on the planet, She likes what she sees here with the light but she doesnt want to spend the money unless it does what she wants. She is looking for a slow fade to where all of the colors are lit at different times, sort of like the multi-color christmas lights, we currently have a LED strip lights but when they fade all of the lights are ther same color then fade into the next color all of them the same again. We paid 156.00 for this set on sale but she was unhappy after the perchase. So before I purchase these I want to make sure that it is what she wants. (they probably dont make what she wants). Let me know it these do that. I think that the 25.00 is a great price compared to what I paid for the set that I have. Thanks for your help with this. Anyone else that has them can answer as well I just asked Herk cause he helped on another matter with the awning remote
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 59, 2020 0,
2021 4 reserved
SYE is offline   Reply With Quote
Old 01-28-2013, 09:00 AM   #653
Herk7769's Avatar
OK, the way the strip I am using works, there are 4 wires that go to the strip (3 LED color "hots" with a single common ground wire). The computer can control lots of actions using the single hot to each color.
EACH color LED can be: ON, OFF, various shades by varying the voltage to the LED and that is it. If all 3 colors are on at the same time it is "white."
No "running lights" because that would involve a control signal line that can turn off the ground wire at each 4 LED pad (alternating) to make the LEDs "run" by alternating the on/off state of that pad.
There ARE strips wired to do that. (I think Turbs has one and might better point you to what she wants).
Old 01-28-2013, 09:24 AM   #654
SYE
SYE's Avatar
Thanks jerk for the info. I will find out from turbs what he has.
Scott & Vicki
2021 4 reserved
Old 01-28-2013, 09:27 AM   #655
SYE
SYE's Avatar
Sorry my phone does an auto correct on spelling. I put in herk and it changed it to jerk. I was not calling you a jerk. Sorry about that!!!
Scott & Vicki
2021 4 reserved
Old 01-28-2013, 09:27 AM   #656
TURBS's Avatar
thanks jerk for the info. I will find out from turbs what he has.
lol "jerk" auto correct at it finest!
Done the same thing long ago.
I just saved herk in my library.
Turbs
Old 01-28-2013, 09:34 AM   #657
SYE
SYE's Avatar
OK turns did you read the original post that herk replied to. He told me to ask you. Dang phone keeps changing herk to jerk!!!
Scott & Vicki
2021 4 reserved
Old 01-28-2013, 09:35 AM   #658
SYE
SYE's Avatar
It also changes turbs to turns
Scott & Vicki
2021 4 reserved
Old 01-28-2013, 09:42 AM   #659
TURBS's Avatar
Huh never noticed ........
Old 01-28-2013, 09:43 AM   #660
Made an alum waterproof box and mounted it up top where it is also protected. Wired the lights to be controlled by the factory step light switch and also added led lights in the step cutout.
Name:	LED Step lights 1.jpg
ID:	23571   Click image for larger version
Name:	LED Step lights 4.jpg
ID:	23572   Click image for larger version
Name:	Strip Light Control Box.jpg
awning, led pad
