03-26-2013, 01:38 PM
#761
Owner/Operator
Herk,
I see that Oldcoot posted about using the Shop Scotch two sided tape to mount under the awning rail.
I also read that you used the tape that come on the LED Strips.
Have you had any problems with the OEM tape on the strips, or had to replace the tape?
I'm waiting for warmer weather before attaching, and will wipe the area with either alcohol or MEK before mounting.
RodeoGeorge
2013 Rockwood 8289WS
Mods: Central Vac, PI EMS-HW50C, 2025RV, (2) SCS225 Trojans, PD9260, Awning Remotes & LED Lights, Eliminators, External Water Filter,, Intellijacks
2008 RAM 3500 Cab&Chassis Hauler Bed, B&W Companion Hitch
All My Modifications are at this link:
https://www.forestriverforums.com/for...ons-36212.html
03-26-2013, 01:59 PM
#762
Originally Posted by RodeoGeorge
Herk,
I see that Oldcoot posted about using the Shop Scotch two sided tape to mount under the awning rail. I also read that you used the tape that come on the LED Strips.
RodeoGeorge
Mine came with the 3M OEM tape also, but didn't last but about 3 or 4 days and started drooping. That's with I used the Scotch Outdoor 2 sided tape. It is useful in a lot of places also.
03-26-2013, 02:20 PM
#763
Owner/Operator
Thanks OC.
Now the questions for you. Did you split the tape to reduce the width, or possibly install two sets of lights to use the entire 1" width?
My thoughts are that if I do not cut the tape down to about 1/2", with one light strip the exposed adhesive will be a dirt catcher.
I'll probably use the Scotch and do it once.
RodeoGeorge
03-26-2013, 02:55 PM
#764
Buy the Good (3M Auto Trim Tape 1/2" wide) Auto Parts Store,No cutting in 1/2 required. Youroo!!
03-26-2013, 03:10 PM
#765
Thanks OC.
RodeoGeorge
I used the 1" and split it on my bandsaw. Lowes only had the 1".
03-26-2013, 04:05 PM
#766
Hi,
Not sure on pricing but Amazon has it here. 1/2" x 15' for 7.22 plus shipping.
link: 3M 03614 Scotch-Mount 1/2" x 15' Molding Tape : Amazon.com : Automotive
crunchman
2015 F-250 FX4
03-26-2013, 04:14 PM
#767
Originally Posted by Cincy6
Curious how these work for you, I saw those too and the reviews are not that good for them.
Greg
2012 Tundra Crew Max 5.7L iForce V8 w/Equal-i-zer 10K
2013 Shamrock 23IKSS
Nights camped in 2012 - 32; 2013 - 31; 2014 - 22 so far
03-26-2013, 05:06 PM
#768
Herk,
RodeoGeorge
I wiped the underside of the awning channel with a 100% alcohol pad (the kind they use for shots) and after it dried just stuck up the OEM tape.
Still solid.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
03-26-2013, 05:52 PM
#769
X2 on the OEM tape. I cleaned the area and used the OEM tape and the strip is still solidly attached. I did use some silicon on the ends to provide a little extra holding power.
TV, 2000 Dodge RAM 2500 Quad cab short bed, Cummins 5.9, Edge Comp, Gauges.
5ver, 2011 Palamino Sabre 31 RETS.
03-26-2013, 05:57 PM
#770
Come to think about it I put goop on the "up wind" end as well (but just to hold the connections from flopping around) but it can also keep the up wind end from unrolling.
03-26-2013, 06:01 PM
#771
Still solid.
I also used alcohol and let it dry, I must have gotten a set with less than good 3M adhesive. I'm lucky that way. Murphy's law is always lurking over my shoulder.
03-26-2013, 06:06 PM
#772
I used a Tip from (Turbo),he said to use Alcohol,I did and it didnt turn out real well!! Youroo!!
03-26-2013, 06:41 PM
#773
I think the set on Amazon is the same we just bought. Haven't attempted to install them yet, will do pix when we do. I thought, originally, we weren't gonna have to use tape at all that they would just fit in the groove. I confess, I did not want to read 77 pages to find the answer ~ is there a short answer?
03-26-2013, 06:55 PM
#774
In my experience; Murphy was an Optimist.
03-26-2013, 06:56 PM
#775
Yep!
It Depends...
03-26-2013, 07:08 PM
#776
Phat Phrog
My DH thinks Murphy is a total arse!! When I ask why, he looks at me and says....did you FORGET how I cuss when I have to fix things???
Kenny n Karen
TV: 2017 Chevy Silverado 3500 LTZ - named Betty
RV: 2017 Columbus 366RL - named Karen’s Camper
03-26-2013, 07:29 PM
#777
Your DH is correct
03-26-2013, 07:34 PM
#778
He is correct. Dealt with the jerk my whole career and he's still an 'arse'!
03-26-2013, 08:25 PM
#779
Owner/Operator
I used that "Murphy's Law" expression many times, but did not know the origin until I started to build a home in Alamogordo, NM. In the museum there they have the sled used in the deceleration test at Edwards AFB in 1949 when the law was "born".
RodeoGeorge
03-26-2013, 10:12 PM
#780
For those who may not know:
Murphy's Law
What ever can go wrong;
will go wrong;
in a way that will cause maximum damage;
and be impossible to repair.
There are several Corollaries.
As anyone who has lived a reasonably long life will tell you: Murphy was an Optimist. Reality is much worse than that.
Murphy's law - Wikipedia, the free encyclopedia
