04-14-2013, 06:02 PM
#1061
Controllers
If I have the IR type can I use the RF type without a problem of getting the lights to function?
2500HD 6.0 Gas/Ext. Cab
2011 Crusader 270RET
2003 Sunnybrook T/T 30FIS
2012 Jeep Compass Limited
1985 S-10 One Owner:
04-14-2013, 06:20 PM
#1062
The controllers are designed to work with all the common LED strip types.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
04-17-2013, 09:16 PM
#1063
Another upside down camper !
I love these new models !
04-17-2013, 09:24 PM
#1064
That way the water drains out better....
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
04-17-2013, 09:26 PM
#1065
And the roof won't leak.
Jill
Jill and Ed and the kitties
1998 Coachmen Leprechaun 31Q
04-17-2013, 09:31 PM
#1066
Installation Complete
Installation finally completed...Tapped into the DC wiring at the outside bug light next to the entry door....removed all the inside stuff from the light fixture, replace it with the controller and the antenna wire...Drilled a small hole in the bottom of the plastic, ran the antenna head out and caulked the hole..Ran the power cable out through another hole on the side of the light fixture up to the light string..everything is caulked up well...with on a short piece of wire leading to the light string...not noticable at all...the antenna lead was attached to the camper side with a tie wrap and a stick pad for holding wires in place...pictures to follow...
Everything works up to forty feet away, in the dark of course...looks spookey behind the ADCO Cover that is still on the coach...
04-17-2013, 09:37 PM
#1067
Originally Posted by Stanleyg
I also mounted led's inside my pantry to come on when the door is opened and off when closed...
Put led ribbon lights in our pantry with a microswitch on the door and earned some BIG points with TOWTA!
04-17-2013, 10:09 PM
#1068
Installation finally completed...Tapped into the DC wiring at the outside bug light next to the entry door....removed all the inside stuff from the light fixture, replace it with the controller and the antenna wire...Drilled a small hole in the bottom of the plastic, ran the antenna head out and caulked the hole..Ran the power cable out through another hole on the side of the light fixture up to the light string..everything is caulked up well...with on a short piece of wire leading to the light string...not noticeable at all...the antenna lead was attached to the camper side with a tie wrap and a stick pad for holding wires in place...pictures to follow...
Everything works up to forty feet away, in the dark of course...looks spooky behind the ADCO Cover that is still on the coach...
This sounds exactly of the install that I am thinking of doing. Would you be able to post some detailed install pictures?
2005 Winnebago Adventurer 38R
Workhorse 8.1/Allison Transmission
Old 2005 Forest River Cherokee Lite 28A
04-18-2013, 07:58 AM
#1069
Awesome, Old Coot, who/what is TOWTA?
Jill
04-18-2013, 08:02 AM
#1070
The One With The Authority! his dw
04-18-2013, 08:14 AM
#1071
I think I'm going to put that on my rear tire cover.
04-18-2013, 08:31 AM
#1072
What is dw?
Jill
04-18-2013, 08:33 AM
#1073
Always Learning
Dear/Darling/Dang/D}%%# wife
#1074
DW dear wife DH dear husband
04-18-2013, 08:34 AM
#1075
I like you definition better
04-18-2013, 08:36 AM
#1076
Ah. Why not just say wife or husband then? I just don't get these acronyms.
Jill
04-18-2013, 08:37 AM
#1077
Faster and easier ?
04-18-2013, 08:46 AM
#1078
Always Learning
Habit, mostly.
DD - daughter
DS - son
AWESOME - Me/Doug
MIL - monster in law (err... mother)
FIL - father
TURBS - emotional issues guy
TV - tow vehicle or television depending on context
TT - travel trailer
FW - fifth wheel or freshwater depending on context
BW - black water
GW - gray water
I type 90% of my posts form my phone. It's just more convenient.
04-18-2013, 08:56 AM
#1079
What is a TOAD?
Jill
04-18-2013, 08:57 AM
#1080
A car "towed" behind a camper !
