04-18-2013, 09:00 AM
#1081
Phat Phrog
Originally Posted by LKicklight
Installation finally completed...Tapped into the DC wiring at the outside bug light next to the entry door....removed all the inside stuff from the light fixture, replace it with the controller and the antenna wire...Drilled a small hole in the bottom of the plastic, ran the antenna head out and caulked the hole..Ran the power cable out through another hole on the side of the light fixture up to the light string..everything is caulked up well...with on a short piece of wire leading to the light string...not noticable at all...the antenna lead was attached to the camper side with a tie wrap and a stick pad for holding wires in place...pictures to follow...
Everything works up to forty feet away, in the dark of course...looks spookey behind the ADCO Cover that is still on the coach...
Way to go LKicklight!, I will show these instructions to my DH to use for our install.....should only take a few weeks! bwaaaaHaaaa! I can say that cause he doesn't read this forum!! I chant wait to see some pic's!
Kenny n Karen
TV: 2017 Chevy Silverado 3500 LTZ - named Betty
RV: 2017 Columbus 366RL - named Karen’s Camper
04-18-2013, 09:05 AM
#1082
Originally Posted by Tonk Mom
What is a TOAD?
You think these acronyms are bad wait until you learn Phrog speak or PHrog latin... it's only just the beginning.
04-18-2013, 09:24 AM
#1083
Well, I need one. Any suggestions? We went to a car dealer yesterday and they kept telling me the cars available can't be towed four down.
Jill
Jill and Ed and the kitties
1998 Coachmen Leprechaun 31Q
04-18-2013, 09:27 AM
#1084
Naw, I prefer to type out the word.
Jill
04-18-2013, 11:06 AM
#1085
VW JETTA phour down. My friend pulled one to Alaska and back. 12,000 mi. no problem.
04-18-2013, 11:43 AM
#1086
Originally Posted by ependydad
Habit, mostly.
DD - daughter
DS - son
AWESOME - Me/Doug
MIL - monster in law (err... mother)
FIL - father
TURBS - emotional issues guy
TV - tow vehicle or television depending on context
TT - travel trailer
FW - fifth wheel or freshwater depending on context
BW - black water
GW - gray water
I type 90% of my posts form my phone. It's just more convenient.
You forgot MILF........lol
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 59, 2020 0,
2021 4 reserved
04-18-2013, 11:47 AM
#1087
Was just wondering how long it was going to take........
04-18-2013, 11:54 AM
#1088
Phat Phrog
Tonk Mom we towed a Honda civic with our previous Class C (31ftr) all the time. We just put it in neutral all the time. Works fine!
Kenny n Karen
04-18-2013, 12:16 PM
#1089
ME
The most common thing for toad vehicles is four wheel drive (not all wheel) and stick shift
2008 Georgetown 350TS
04-18-2013, 01:44 PM
#1090
Not long when I am involved....knick name gutter mind!!!!!!
Scott & Vicki
2021 4 reserved
04-18-2013, 10:56 PM
#1091
Owner/Operator
Sorry, grabbed the wrong thread.
RodeoGeorge
2013 Rockwood 8289WS
Mods: Central Vac, PI EMS-HW50C, 2025RV, (2) SCS225 Trojans, PD9260, Awning Remotes & LED Lights, Eliminators, External Water Filter,, Intellijacks
2008 RAM 3500 Cab&Chassis Hauler Bed, B&W Companion Hitch
All My Modifications are at this link:
https://www.forestriverforums.com/for...ons-36212.html
04-19-2013, 09:18 AM
#1092
Originally Posted by Barney1
UPDATE:
I received my LED light strip yesterday (Apr 18th) that is 8 days from Hong Kong. I can really complain about that.
PROBLEM:
On the shake down test the light strip didn't work properly.
The blue LEDs on the strip are always ON when there is power to the unit.
^ Oh look the sad emoticons are blue, how apropos!
STEPS TO RESOLVE:
I contacted the eBay seller. After some back and forth troubleshooting the eBay seller sent me the reset procedure for the 44 Key LED strip controller (part# 073-004). NOTE: You won't find the part# on the controller.
I will post the rest procedure below.
For me the reset did not work.
Form this the dealer is concluding that the fault must be with the strip. The have offered to send me a new LED strip at no charge. I said sure.
I am now in wait mode again
Here is the reset procedure
HERK PUT THIS IN YOUR LIBRARY.
Barney
2020 Salem Cruise Lite 241QBXL
2016 Ram 1500 Big Horn Eco-Diesel
Previous Trailer -> 2012 Rockwood Roo 233s
-> 1996 Jayco 1207
04-19-2013, 09:21 AM
#1093
Site library as well.
04-19-2013, 09:26 AM
#1094
Led light operation
Found out the hard way, when checking the install, be sure it is DARK outside, the controller does not like SUNLIGHt and will not work...almost ripped the whole install out before some really smart PHrog got me back on the right track..Line of Sight on the Controller...got to be able to see the Transformer Sensor...
2500HD 6.0 Gas/Ext. Cab
2011 Crusader 270RET
2003 Sunnybrook T/T 30FIS
2012 Jeep Compass Limited
1985 S-10 One Owner:
04-19-2013, 09:33 AM
#1095
The issue is that moving parts need lubricated and almost all automatic transmissions have a pump drive by the engine, so no running engine no lubrication to the output trans bearing. You go towing, even in neutral and you're spinning these parts and they'll fail.
Stick shifts don't have pressure lubed transmissions so it's not an issue. Most 4X4s have transfer cases that can be put in N and then the trans won't spin and they are lubricated like a manual trans so it's not an issue.
Chris, Wills (16) Evie (13) & Toby our collie (6)
2011 Grey Wolf 28BH
2013 Chevy K1500 Crew w/ Reese StraitLine Dual Cam
Nights camped 2011: 11 2012: 18 2013: 12 2014: 12 2015: 13 2016: 56 2017: 8+
04-19-2013, 09:45 AM
#1096
I don't mention the sink cause we don't use it as such.
I've installed a pony keg oph coors light in the rear bunk and its plumbed to my beer dispenser. Ie the thing you called sink.
Just sayin
SWEEEET!!
Steve Dagro
04-19-2013, 09:47 AM
#1097
Always Learning
Could we please move the TOAD discussion to its own thread?
04-19-2013, 10:22 AM
#1098
Phat Phrog
UPDATE:
PROBLEM:
STEPS TO RESOLVE:
Thanks for the pic! That is the same set I have! Have not installed yet....go figure....but good to see how to reset if I have problems!
Kenny n Karen
04-19-2013, 10:48 AM
#1099
I have! Thank you so much. What a great tip.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
04-19-2013, 11:04 AM
#1100
I have my moments.
Although few and far between.
Barney
-> 1996 Jayco 1207
