05-09-2013, 09:37 PM
#1241
Like Herk and others will attach under the awning rail and run the wire down the awning support and into the pass thru.
I have identified a wire that feeds power to the hitch light. I have cut into that and run a wire over to where I will put the controller. However now that that is done not sure I connected in correctly.
I cut the red wire - so now have two ends. Then attached the end of the new red wire and nutted all three together. Ditto for the white wire. The hitch light works. But in doing this I blew a fuse. After replacing the fuse the red LED beside is still lit up.
What did I do? Is there some reset I should do? Maybe hit the battery disconnect then reconnect? Yikes hope I didn't blow something in the power panel.
Thanks...
Heather & Jim
2017 Ford F150 4x4 EcoBoost
2013 Rockwood 2703WS
05-09-2013, 09:47 PM
#1242
LKick, thanks so much! You are totally awesome.
Jill
Jill and Ed and the kitties
1998 Coachmen Leprechaun 31Q
05-10-2013, 02:58 PM
#1243
Finally Finished but NOW???
After digesting all of the information on this forum, I finished my finished the insdatllation of the light strip on my TT... I opted to install a dummy light fixture on the side of the trailer to use as a electronics box to hold the IR Sensor / receiver. Just before I attached the light strip with 2 sided tape I tested everything and it was a GO!.. I carefully attached the light strip being cautious not to bend or twist it in any way.. Once installed, I turned things on, and everything still worked OK with the exception of when I selected full GREEN when a small segment failed to light (less than 2 inches).. when other colors or shades were selected with the remote, these very same LEDs came on with the color selected and looked normal.. ONLY DARK GREEN WON'T ILLUMINATE... If it is something simple that I can fix, I will, BUT since everything else works fine, I won't hassle trying to undo the 3-m tape job that holds it up.. I have attached a picture of my Junction Box/Dummy Light and a picture of the light strip on GREEN... Any ideas or should I just carry on smartly and avoid Green?
Ted
2010 T25KS Wildwood
2006 F-250 SD
STGCM(SW) USN Ret 30 yrs.
05-10-2013, 05:23 PM
#1244
Hi,
I would leave them be, unless green is your favorite color?
Nice clean install. Looks nice!
crunchman
2015 F-250 FX4
05-10-2013, 05:40 PM
#1245
Owner/Operator
Sounds like the controller chip for that segment of LEDs has failed on the Green input. It could be an open (separation) in the printed circuit trace leading from the Green conductor to the chip. With solid Green selected, you might try applying pressure on that segment of the LED strip flexing it as much as possible and see if the Green comes on. If so, you'd need to do some coating removal and fine soldering to attempt to bridge the open.
The other option would be to go to the cut lines on each side of the "Greenless" segment, cut that segment out, and solder in a good segment.
RodeoGeorge
2013 Rockwood 8289WS
Mods: Central Vac, PI EMS-HW50C, 2025RV, (2) SCS225 Trojans, PD9260, Awning Remotes & LED Lights, Eliminators, External Water Filter,, Intellijacks
2008 RAM 3500 Cab&Chassis Hauler Bed, B&W Companion Hitch
All My Modifications are at this link:
https://www.forestriverforums.com/for...ons-36212.html
05-10-2013, 06:32 PM
#1246
Phat Phrog
You guys are so smart and creative!
Kenny n Karen
TV: 2017 Chevy Silverado 3500 LTZ - named Betty
RV: 2017 Columbus 366RL - named Karen’s Camper
05-11-2013, 12:05 PM
#1247
Will let it ride...
I have decided to let the small area without dark green stay as-is... I have another segment that I could put in but who knows what damage I might inflict by trying to remove the strip from the 3-m double sided trim tape.. that stuff really sticks..
Ted
2010 T25KS Wildwood
2006 F-250 SD
05-11-2013, 12:06 PM
#1248
Good looking install.
I did something I haven't seen yet on here (I think) and thought I'd share.
I wanted my LED strip on my awning tube, so I know I needed to hook it up after the awning was deployed. I already have an extension I bought from Amazon, and also wanted to utilize the outdoor light above the door for simplicity, but did not want to take it off or modify the internals to tap power so I can use the light as stock again if needed.
My brain fart is this - I used a spare bulb, broke off the glass and removed the filament, then soldered the included adapter plug to the exposed leads making sure I used heat shrink tubing to insulate them,
This is what it wound up looking like - pretty simple really.
Then just placed it all in the housing with the 4 pin connector and IR detector hanging out of a small hole in the bottom of the housing. I just need to silicone up the hole, and done.
I already tested it and it works great. Maybe this will help other forum members.
2020 SOB - Jayco North Point 387RDFS
2013 Crusader 325RES Touring Edition - SOLD
TV: 2018 GMC Sierra Denali HD CC SRW L5P Duramax Curt Q20
05-11-2013, 12:30 PM
#1249
Awniing Tube Attaching
How did you attach your light strip to the awning tube? Tape or a temporary mount of some kind?
Ted
2010 T25KS Wildwood
2006 F-250 SD
05-11-2013, 12:51 PM
#1250
I had this problem with one segment of my first strip. Although all worked fine before I mounted them; when I stuck them up one of the leds was not making good contact with the printed circuit. (there are 4 pins on each led cluster).
I believe it was a cold solder joint.
I pressed on each one until I found the one that lit up when I put pressure on it.
Once it lit up, it worked until I moved the trailer. I had to repeat the pressure after every stop to get it to work for about a week. Suddenly "It is fixed" and have had no trouble now for over a year of camping.
I think the cold solder joint is now "mooshed" together and making good contact.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
05-11-2013, 03:19 PM
#1251
What kind or gauge of wire did you use on a power awning and how or where did you thread it to connect to the trailer. I've got the LED strip, but can't figure out how or where to attach power. I'm a newbee so give some detail. Thanks.
05-11-2013, 05:19 PM
#1252
Cargo Hole
Just finished installing two three Bright White Led Ribbon Strip lights in the cargo hole...The factory only had one light in the cargo area, the other was in the service compartment...now with 300 LED's I believe this will solve my problem...Can't wait until it gets dark to go out and test it...Still have some more LED's to install...One goes in the pots and pans compartment for DW...the other around the inside of the compartment under the bed....think that will about do it for a while..
2500HD 6.0 Gas/Ext. Cab
2011 Crusader 270RET
2003 Sunnybrook T/T 30FIS
2012 Jeep Compass Limited
1985 S-10 One Owner:
05-11-2013, 05:26 PM
#1253
I used telephone wire (4 conductor) to connect the lights to the control. I used some red and black 2 wire I had in the garage for the 12 volt DC. It only needs an amp or so and wire size is not all that relevant for the power. Look at the 12 volt pigtail they give you. Anything bigger than that is overkill.
05-11-2013, 07:55 PM
#1254
Just regular double faced tape. I didn't go with the fancy outdoor tape, as I don't expect it to get very wet. I can always change it later.
05-11-2013, 09:06 PM
#1255
Herk7769,
Where did you install the strip on the exterior. I've seen some attached to the trailer just under where the awning rolls up to store, others in the barrel of the awning when it is extended. Looks like your's is on the side of the trailer from the installation pic you took. BTW, great response with the pic attached, I see that the sensor poretion of the control is the only thing on the outside. If your's was installed in the barrel of the extended awning, how did you afix the long wire?
Thanks,
Happycampers2
05-11-2013, 09:18 PM
#1256
Herk7769,
Thanks,
Happycampers2
Herk and a few of us mounted them on the bottom of the rail holding the awning, not on the fiberglas side of the camper.
05-11-2013, 09:29 PM
#1257
Missing Link
Same way I did mine.
2014 Puma 30-DBSS
2014 Ram 2500 Mega Cab 6.4L
05-11-2013, 10:11 PM
#1258
Picture is worth a thousand posts...
05-12-2013, 06:51 AM
#1259
SHOW OFF !! It looks great as usual.
05-12-2013, 06:59 AM
#1260
Thanks. By using the bottom of the awning attachment rail, the LEDs are pointed kinda down and not straight out (side mounted). Careful placement will allow a double strip if you want to.
The wall mounted one's I have seen have had a lot of glare when looking towards the camper (IMO).
I have not seen a tube mounted set, but if installed in the slot some of the light looks like it might be blocked and the accessory slot would be unavailable for sun screens or other cool accessories.
