03-01-2021, 01:30 PM
My Water Pur filtration iced and broke
I knew a freeze was coming and shut it all down but didn't drain the filter carrier. That part held up wonderfully but as the ice.expanded the pvc cap blew its threads and popped the filter cannisters right off.
Normally I would just look for a replacement part but they are OUT OF STOCK everywhere I look.
This caused me to look at specs like filtration and gpm and I have to say it doesn't look good for a $40 filter (kw1, 2.5 gpm, temp range 40 to 165 F).
Anybody out there replumb their water filter? If so, what with?
Water flow that dies at 40F isn't rugged enough for me. I can fix some of that with external insulation, but 2.5 gpm, seriously?
03-01-2021, 01:48 PM
A lot of members just by-pass water filter and use and external one. See many threads in link below.
https://www.google.com/search?q=wate...iverforums.com
Fonzie
03-01-2021, 04:05 PM
03-01-2021, 06:23 PM
That's about average for RV water pumps. I find it more than adequate in my TT for the shower and faucets.
Even in a Stick and Brick house the current codes limit water flow from a faucet or shower heat to less than 2 GPM or less.
Maybe more is allowed when filling a 200 gallon soaking tub or a Hot Tub/Spa.
03-02-2021, 12:18 PM
I managed to crack my filter housing (KW5 used in pop-ups and A-frames) by having a metal box slide into it while trailering.
Since both sides of the plumbing are 1/2" threaded connections, I simply replaced the filter temporarily with a piece of hose cut to about the right length attached to 2 female connections. I simply screwed the replacement hose in place of the filter top.
I later bought a new filter and installed it. I keep the hose with the fittings in my toolbox as a quick replacement for the filter.
Fred W
2019 Flagstaff T21TBHW A-frame
03-02-2021, 12:42 PM
Trailer Park Supervisor
Tons of people replace the whole unit. Just type in 'water filter replacement' in search window and enjoy the thousands of posts on this subject.
Yes, I drink the water!
03-02-2021, 12:48 PM
Btw here are pics of the impossible to find part. You can see in the third one that the pvc broke around the screw threads popping off the clear plastic filter housing.
Any ideas where I can find just that piece in the interim? There's absolutely no markings on it.
Just bypass it using whatever connections necessary where it originally existed and then use your filter of choice on the OUTSIDE at the hydrant. You'll never need to worry about it during winterization/dewinterization again. (take it inside during the winter or throw it away if using disposables.)
03-02-2021, 01:08 PM
Bypass the interior filter... they can make a mess if they fail while hooked up to water and you don't notice for awhile and are often in inaccessible locations in the trailer
many solutions depending on your own abilities
2014 Shamrock 183
03-02-2021, 01:32 PM
Is this a new unit that you haven't camped in before? If you've camped in it before, did you have problems with the flow rate before you read the specs? If not, why does it become a problem now that you know the specs?
2018 Coachmen Leprachaun 210RS with DW, Nanuq the Samoyd puppy and the cat.
03-02-2021, 02:41 PM
Originally Posted by fonzie
Agree! Forest River’s choice of water filters is terrible. I have bypassed this gem and use an external one. You have a much better choice in filters if you go external.
2014 Coachmen Brookstone 325RL
2015 Chev Silverado 2500 Diesel.
03-03-2021, 08:55 AM
A couple of 1/2" male Pex fittings and a short piece of hose will remove the water filter housing completely.
Then you can use these outside the camper, at the fresh water supply. If you do a search on the efficiency of the different water filters available these filter out more and work better than even the larger canister style filters.
https://www.walmart.com/ip/Camco-400...AaAmQJEALw_wcB
We change ours out at the first trip each season.
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
03-03-2021, 09:15 AM
If using these Camco filters you need to run some water through it before hooking up to the trailer/RV. The water will come out black and go right into the water system.
03-03-2021, 09:18 AM
The package tells you that. It is necessary whenever you use a filter that has activated charcoal as part of its filter. That activated charcoal is what makes it so effective BTW.
The water filters on both our home reefers do the same thing.
