Originally Posted by 325BH
Why, because I call out those that are ST fanatics?
No, because you have chosen to "pick a fight" with someone who was not defending ST nor offending LT. I simply stated my interest in the Endurance tire and as brief an explanation I could come up with as to why.
It is quite funny hearing how only ST tires are designed a certain way and are the only tires that are built for trailer use
By definition, ST tires are designed for trailers, LT tires are designed for light trucks, and P tires are designed for passenger cars....I fail to see how that can be funny. Maybe others you have argued with in the past were not aware that P and LT tires are allowed on trailers, but I am not one of them (as shown by my post above).
and how those using anything other than ST tires are foolish...
Please re-read your post and see who's calling who foolish.
yet ST tires are the ones blowing up (you can't swing a stick without hitting a "my ST blew up" thread)
This is to be expected, considering the law of large numbers. This is also why I spent many, many hours researching and trying to learn as much as I could about RV/trailer tires. I very seriously considered switching to LT but in the end, I didn't.
and everyone who has switched to LT tires have never looked back.
You got no argument from me here. I seriously considered LT tires myself before deciding to stick with ST. NOTE: I have never once called (or even considered) anyone "foolish" for choosing something other than what I chose for myself. At least not where tires are concerned anyway.
Any the fanatics completely dismiss the idea of LT tires rated for trailer use.
I can't speak for anyone other than myself on this but I, for one, am perfectly aware that LT tires are rated for trailer use. It is my (current) belief however, that they are not the best tire for the job.
It is very amusing watching everyone defend ST tires by saying the only reason they blow up are:
You drove too fast
You were overweight
You were under inflated
You don't have a TPMS
You don't zap them with your thermal ray-gun every 25 miles
The moon was full
I'm not sure whats funny about this either (other than the last couple which were obviously in jest). It is well known that these are the major contributors to tire failures of any type or design. Personally, I believe there is another major contributor that is usually not mentioned...I'll call it "abuse during use". What I'm referring to is the all too common curbing of the trailer when parallel parking, driving up/down curbs when trying to pull into and out of driveways and such, and turning the trailer so sharply that the tires scrub across the surface.
... yet nobody with LT tires (or something bigger) ever seems to have problems.
Duly noted, yet not enough reason for me to switch (yet).
Lots of heads in the sand on this subject.
This doesn't deserve a response.
The unfavorable posts come from both sides, so your "friends " comment is just another "nice way" to get your dig in.
I'm not sure what you mean by "get your dig in". You asked me a question, and I answered it. You then responded with a snide remark. My response to that was the nicest way I could come up with to basically tell you to kiss off (I wrote out and deleted several other nastier versions first).
I had a feeling where you were going with your initial question and I almost didn't respond to it...I should have stuck with my gut on that one.
My apologies to everyone subjected to reading this trash.
