While many people use wood laminate planks, they are subject to water damage. Use 100% vinyl planks instead. But use at least 5 mm thick planks, thinner planks have very thin edge locks that are subject to damage and separation. Also, vinyl planks handle temperature extremes better than wood planks, so they can tolerate a smaller edge gap. In fact, instead of using bulky baseboards to hide the gap, a matching color flexible caulk will work just fine in the small area of an RV.
I have installed Smartcore from Lowes, while better than Allure from Home Depot, my real preference is Lumber Liquidators, Rustic Acacia or comparable. In a house, this stuff needs 1/2 the gap of wood laminates. Have it in my house and there are several places in the kitchen with complex shapes, that I simply used a 1/8 inch gap filled with caulk. Even with white cabinets and a dark floor, the floor appears to run right under the cabinets.
Lumber Liquidators also makes a 1 mm thick underlayment. It is expensive, but will improve the look and durability of the job. Flaws and imperfections in the sub flooring will not telegraph thru the flooring. And installed with the smooth side up, it allows the entire floor to float as a single piece, otherwise over time, individual planks can move differently resulting in gaps at the joints. And in an RV the floor will flex and temperature range will be worse than any house.
Larry Day, Texas Baptist Men volunteer since '01
'13 Silverado LT 3500HD D/A CCSB 2wd, custom RKI bed
'17 Puma 351THSS toyhauler
