Old 05-11-2015, 08:16 PM   #41
Does this work with the Domestic thermostats?
jlkunze is offline   Reply With Quote
Old 05-12-2015, 06:09 AM   #42
Canadian Member
Yes. In fact, you'll probably find more threads about switching out the Dometic analog thermostat than the Coleman Mach.
2019 Rockwood Signature 8290BS, Reese Revolution pinbox and B&W Patriot 18K hitch
itat is online now   Reply With Quote
Old 07-04-2015, 09:56 AM   #43
Followed this today and it worked perfectly. Thanks so much.
hazmat91180 is offline   Reply With Quote
Old 08-18-2015, 02:08 PM   #44
ohcnda's Avatar
ac fan just runs
I.installed a Honeywell rth2300b today. All works fine except when on cool the fan runs non stop regardless of the temp setting. I did not attempt to install the hi lo switch as I want it to be on high when the ac is on. The thermostat does have a fan auto and on switch but it runs the fan on either setting. Is the switch for the furnace perhaps?
I really don't mind that th fan runs but would like to know if there is a way for it to work on auto?!
ohcnda is offline   Reply With Quote
Old 08-18-2015, 06:31 PM   #45
Witch Doctor's Avatar
On auto your fan should cycle with the A/C. I would check that you do not have any wires touching. That is not correct, check your subase. I was in HVAC for 20 years, and that can be the only problem unless the sub base is'nt any good....
Coachmen M/H
Concord
2018 / 300 DSC
Old 08-18-2015, 07:26 PM   #46
ohcnda's Avatar
I am sure I don't have any wires touching. What are the odds the sub base is bad? I have 2 wires left that I didn't hook up, the low speed and the blue. Should the blue be attached somewhere? Maybe it is what triggers the relay for the fan? Everything I have read said to tape it and leave it
Old 08-18-2015, 07:45 PM   #47
ohcnda's Avatar
Re checked wires.. turns out that the wire was in the wrong port... oops!
Got it in the right on on it works like a charm...imagine that!
Thank for you help
F150 Crewcab XLT
2011 Flagstaff 831RKSS
OHCNDA
Old 08-19-2015, 02:55 AM   #48
Thank for you help
Your very WELCOME, enjoy your new stat with an even temp. Make sure you plug the whole the stat wire came through at the wall or you will still have funny temperatures (up and down)......
Coachmen M/H
Concord
2018 / 300 DSC
Old 12-21-2015, 07:58 AM   #49
Ambassador
Ken K.'s Avatar
lol now we know what the grey and blue wires are for...
2016 Ford F250 Crew Cab 6.2 L w/Ride Rite Air Leveling System.
2017 Rockwood Signature Ultra Lite 8335BSS
Ken K. is offline   Reply With Quote
Old 01-06-2016, 09:33 PM   #50
Exclamation Use a fuse
I replaced my Coleman Mach analog with the basic Honeywell digital.
It melted and caught fire on the third trip after replacing it!
The old thermostats had a 12v 2a fast blow fuse on the 12v input.
I would recommend putting one in line, that may have prevented the meltdown we had.
Don't know for sure what caused it, but I do know that turning on the heat caused the lights to dim, so I turned it right back off. Evidently that was long enough to make something short and slowly melt it down!
They put a fuse on the old ones for a reason. We should make sure we use one on replacements.
Brian
brisley is offline   Reply With Quote
Old 01-07-2016, 02:55 AM   #51
I never heard of such a problem with a melted stat. It should have been just running off the 12 volt battery in the stat. As far as your lights dimming what might have caused that is your 12 volt furnace motor pulling to many amps. I suggest that you get the furnace blower looked at plus the whole unit. Always a good idea to put a fuse in-line. Thankfully you were there to catch it and your okay. Did you put the old stat back on and try it again?
Coachmen M/H
Concord
2018 / 300 DSC
