07-28-2020, 02:37 PM
New Lippert window and sewer pipe storage
2016 Rockwood 2703WS Sapphire
2016 F250 SD 6.2L
08-05-2020, 06:16 AM
I also made a fence post sewer hose holder, and like yourself painted it black. When I traded my previous trailer in, it was transferred to the new one. It's a huge timesaver having it right next to the dump valve. Did you also use the rain gutter inside?
Here is mine...
2020 Wildcat 322RLI
- Pulled by a 2022 Silverado RST Crew Cab 1500 4WD
-- 6.2L/10-Speed Trans
08-05-2020, 06:37 AM
OMG saving this. I like it!
2013 KZ Sportsmen Classic 20RBT
2021 Forest River Salem 29VBUD
03-07-2021, 07:13 AM
Sid & HRH MISSY, SHIH TZU
2019 WILDCAT 28 SGX
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2023 69 DAYS
[SIGPIC][/SI[SIGPIC]
03-18-2021, 12:21 PM
I like reading these mods you guys are on top of it Thanks for ideas . Adapt and over come problems and make life easy !
03-18-2021, 08:13 PM
Pseudonym
Are y’all getting 5” posts? Or are they just one size?
03-20-2021, 08:18 AM
IIRC there exist both 4" and 5" post covers. Not all stores carry both sizes. Shop around.
TV: 2021 Ford F-150 4WD XLT Crew w/ 3.5L EB & HDPP, payload: 2,416#.
Camping nights: 2021, 52; 2022, 99; 2023, 88; 2024, TBD (Est: 80+)
03-20-2021, 08:59 AM
Why get a 4” post as that’s the same size as the bumper when the gist here is to create more & better storage than our square tubes bumpers can provide.
03-20-2021, 09:33 AM
If that response is directed to me, I didn't intend that someone would buy a 4" post cover. I had to shop around to find the 5" because not all stores carry them.
03-20-2021, 10:23 AM
READING Post no one says what size they used or if they did I missed it looking at pictures it looks like 5" post because hose would fit tighter in 4" post . Plus gutter would not side in 4" post . I'm I right about this ?
03-20-2021, 10:39 AM
03-20-2021, 12:47 PM
That reflects my experience when I built one in the past.
03-20-2021, 04:23 PM
I had to get my 5" cover at Lowes as my local D-Pot doesn't (or did at the time) have them in stock. The gutter came from a local Ace Hardware.
2020 Wildcat 322RLI
03-21-2021, 07:57 AM
Follow up on sewer hose stowage:
I did use 5" vinyl fence post, this size has to be used in order for the rain gutter
to slide in and out. I used Amerimax rain gutter which has no lips. I used small aluminum POP RIVETS just long enough to penetrate the two walls if the 5" Vinyl cap & fence post wall. The only screws I used were the screws used to
mount system to RV outer frame lip. I did use # 8 SS screws 1/2" long to mount Vinyl handle from Lowes. Trim handle to fit contour of end cap with razor knife. I shortened the 5" fence Post by 7" For a good fit Underneath RV. Used 1/2" wide aluminum flat bar for support from LOWES. I had to use a 1" X 2"
5" long furring strip to mount between 5" post and frame of RV to clear the Propane line on one side. I used two sheet Metal screws to prevent wood block from moving. After installation of completed system I drilled 3/8" holes in bottom of 5" post and rain gutter to let any water drain from sewer hose. I did use AMERIMAX end caps pop riveted in place in the end of rain gutter. I also used small fender washers underneath the knob screw head and handle from Lowes.
2019 WILDCAT 28 SGX
03-21-2021, 09:44 AM
Good post Thanks for the info will use it to make my hose holder .
03-22-2021, 10:04 AM
These ideas are brilliant!!
Past Tow vehicle but still own: 2017 Ford Expedition XLT EL factory tow package. Added towing mirrors, 10 ply tires on separate rims, sumo springs, larger rear sway bar.
Current tow vehicle: 2020 Ford F350 Lariat supercab
4x4. 7.3 gas. 4,400+lb payload capacity.
2021 Cherokee Greywolf 23MK
Equalizer 1,000lb WDH
