Old 03-01-2021, 06:38 AM   #1
No exhaust vent over stove
Hello,
Itís been a while since my last post, my wife and I wanted to get back to camping so I recently purchased a 2019 Palomino Real Lite 181.
Unfortunately it does not have a hood exhaust fan over the little 2 burner stove or any exhaust vent anywhere within the living area to remove heat and unwanted orders.
Has anyone added an over the range exhaust fan to their TT?
Iím not sure how easy it will be to obtain a wall schematic for my TT model from Forest River.
Iím pretty handy so I feel comfortable doing it as long as I know whatís behind the wall before cutting a hole in it. Any advise or suggestions will be greatly appreciated. Thank you in advance JC
2019 Palomini RL181
2013 GMC Sierra All Terrain
BirdmanII is offline   Reply With Quote
Old 03-01-2021, 09:53 AM   #2
SeaDog's Avatar
I doubt you will get any kind of diagram showing wall wiring or configuration from FR. You may be able to kill two birds with one stone by installing something like a fanatic fan in the ceiling instead of the kitchen hood. JMHO
Retired Navy
2016 Flagstaff 26 FKWS
Old 03-01-2021, 10:59 AM   #3
dont burn your food .nothing better than bacon smell all day long . I love it. camping, bacon and eggs and a biscuit. stop by.
Thomas ho is online now   Reply With Quote
Old 03-01-2021, 11:20 AM   #4
SeaDog, thanks for your reply and suggestion, the fantastic fan might be a good option if I can rout the wiring.
Old 03-01-2021, 11:23 AM   #5
Thomas Ho, it's not me that burns the food...But seriously it's more about the heat. Thanks
2019 Palomini RL181
Old 03-01-2021, 11:44 AM   #6
Georgia Rally Coordinator
aceinspp's Avatar
The last tt I had, had the vent cover over stove however there was no outlet to vent to the out side. There was a roof vent near the stove so a fanatic fan in its place. Later RJD
2020 Shasta Phoenix SPF 27RKSS
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
Days camped 2020 49 days camped 2021-10
aceinspp is online now   Reply With Quote
Old 03-01-2021, 02:51 PM   #7
Kitchen fan
Replaced ceiling vents with a Fantastic roof vent. Wife can turn the fan on with the remote. Best investment we have made.
Mary, owner. David, driver. Tucker, door bell.
2008 Georgetown SE 350:
Dave Bulkley is offline   Reply With Quote
Old 03-01-2021, 05:17 PM   #8
I don't know your rig and you didn't mention if there is a microwave oven above the stove. If there is a microwave with a recirculating filter hood it may be easily converted to an exhaust. Most microwaves with hoods can be converted, if you don't mind cutting a hole in the camper wall. Other than that the suggestions for the Fantastic make a lot of sense.
DrLewie
Flemington, NJ
Former: 2007 Cardinal 30W LE
Now:2018 Arctic Fox 27-5L
2008 Ford F-250 Long Bed Diesel
Total of 30 Months on the Road Since 2008
DrLewie is offline   Reply With Quote
Old 03-01-2021, 11:07 PM   #9
HerveVR's Avatar
Originally Posted by BirdmanII View Post
Hello,
You wrote: Iím pretty handy so I feel comfortable doing it.
So find a suitable hood fan (keep the receipt in case you have to return it back) and check the mesurements to find where the exhaust hole has to be cut.
Cut the wall from the inside; generaly it is a tiny luan (or so ) paneling.
Doing so, you will be able to find what is in the wall.
If no major hindrances are found, keep going cutting to the outside finish wall and install the hood.
If you find hindrances, you can put back the inside panelling cut with glue and cover it with a backsplash panel approved by DW.
Return the hood to the store.
Good luck !
2012 Lexington 265DS
HerveVR is offline   Reply With Quote
Old 03-02-2021, 01:23 AM   #10
Sometimes you just have to open a window.
Look for a fan switch to be sure. Some do not vent outside.
ppine is online now   Reply With Quote
Old 03-02-2021, 02:28 AM   #11
I appreciate everyone’s comments and or suggestions, I think I’m going to follow HerveVR’s suggestion, I have access to 12V power over the kitchen cabinets. The only light closest to the roof vent currently installed is controlled by a switch. Thanks
2019 Palomini RL181
Old 03-02-2021, 07:30 AM   #12
FR3 Grampy
I have the same problem...I contacted FR and they sent me the schematics for the outside walls. I'll do my modification this spring.
Scottmarm is offline   Reply With Quote
Old 03-02-2021, 07:45 AM   #13
Iíll contact Forest River, hopefully theyíll do the same for me. Thanks
2019 Palomini RL181
Old 03-02-2021, 11:22 AM   #14
Sammici's Avatar
Birdmanll, I have sister TT a Palomini 181. I feel your pain because we havenít cooked a breakfast yet that hasnít set off the smoke alarm! We open opposite windows from stove, turn on the fantastic fan in bathroom and even that doesnít help all the time.
I also thought about putting a vent over stove but someone from the factory decided that was a good place for a speaker. If you find a solution Iím interested in hearing about it.
Sammici is online now   Reply With Quote
Old 03-02-2021, 12:57 PM   #15
Sammici, Iíll post some pictures when Iím done. Mine does not the speaker under the cabinet, the speakers are on the side of the pantry / cabinet.
2019 Palomini RL181
Old 03-03-2021, 08:49 AM   #16
Sammici's Avatar
Thanks BirdmanII.
I found a through the wall powered vent on Amazon that I may try to install.
Old 03-08-2021, 05:03 PM   #17
Sammici,
I was advised by Forest River / Palomino that thereís a beam behind the wall where the cut out would be for the vent, they believe the vent in the ceiling over the bed is satisfactory. Unfortunately the only option is to replace that vent with one with a fan and deal with the electrical part of it. Also FYI, I inquired about the schematic for the rear wall in the event I wanted to add a roof ladder. They said no backing on that wall to support a ladder and that the roof on Palomini lites itís not a walk on roof. Better start my Matrix training if I need to service the roof. Not sure what Iíll decide but will keep you posted.
Good luck to you.
2019 Palomini RL181
Old 03-14-2021, 08:05 AM   #18
Sammici's Avatar
BirdmanII,
Sorry to hear that. I also gave up on installing the vent through the wall because thereís not enough room between the window and side pantry for it.
Itís strange that they told you no ladder can be installed because mine came from the factory with one. The ladder is included in the off-road package which I do not have.
My DW told me to stop spending money and just put a little fan thatís on a clip(which I use at night over the bed)in the window on exhaust when Iím cooking inside. I hate to admit it but sheís right and it will probably work just fine! Good luck.
Old 03-14-2021, 08:20 AM   #19
Sammici's Avatar
Originally Posted by Sammici View Post
BirdmanII,
I actually just went to the Palomino website and they dropped both of our models. And now they have a badlands edition that does include the ladder from the factory. Go figure.
Old 03-14-2021, 10:14 AM   #20
Sammici,
I purchased a 20Ē ductless range hood, itíll work for me, it has a removable filter that can be cleaned and reused. Also installed a stove cover that works as extra counter space when stove is not in use and as a back splash with sides. See attached.
2019 Palomini RL181
vent
