Originally Posted by Urge
Hi all
I have a 282RK and one side of the fold out steps pulled through the floor!!
My floor is the thin plywood and styrofoam version. My question is if I get the one piece steps is this “sandwich “ floor sturdy enough for these stairs???
My copilot is insisting on a step upgrade.
Thanks 🖖
George
Investigate through bolts backed with a steel strap rather than just washers. Two or three bolts...perhaps 3/16" diameter, through the floor and backed with either a steel strap full width OR "fender/body" washers will be SUPER strong. You may need to remove some screws or "nails" in the coroplast to gain access, but that would be an indestructible attachment. Three bolts would be enough, and the rest of the fasteners could be screws....to fill all the holes in the mounting plate.
Use bolt heads taht match the countersink profile of the supplied screws, and paint the bolt heads to match the screws (if needed) before installation.
Absolutely use stainless steel (to prevent corrosion), and then use nylock nuts to ensure things stay together.
Jim & Renee
2020 Jayco Jay Feather X-213
Every weekend boondocking in the National Forests or at
Lake Vallecito.
