Old 02-01-2022, 09:25 AM   #1
Outdoor Griddle for 179DBK
Anyone know which griddle this is? I would like to add one to my 2022 179DBK. Ours currently has the drawer above where this griddle sits.
Thanks,
Andy
Araubuck is offline   Reply With Quote
Old 02-01-2022, 09:28 AM   #2
Looks like the older style (front grease drain) 17" Blackstone.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=101
Old 02-01-2022, 09:38 AM   #3
Thanks! Yes it does. Any idea on the sliding bracket mechanism? This that is custom or an off the self item?
Old 02-01-2022, 09:46 AM   #4
Most of the sliding shelves in R/Vs are specific to the application so you might contact a dealer and see what they suggest or simply start looking online for something that might fit YOUR application. There are plenty of steel sliding shelves out there something like these...
Old 02-01-2022, 09:58 AM   #5
Thank you very much. I found a YouTube video on how to make one.
https://youtu.be/lJ3UC3E9FR8
But I will start looking at these metal ones too.
Thanks again,
Andy
Old 02-01-2022, 10:09 AM   #6
Homebrew's Avatar
This is a nice feature but does not come out far enough to prevent grease from making a mess of your RV.
I’ve seen someone with the full basement tray which comes out almost 3 feet. They positioned there stove at the end of the tray which kept the grease from splashing on the RV.
XLR Thunderbolt 300X12HP
2014 Ram 3500 DRW
Homebrew is offline   Reply With Quote
Old 02-01-2022, 02:53 PM   #7
Dobbs from WI
As Homebrew mentioned the grease is a problem especially when cooking smash burgers when the griddle is too close to the trailer.
I use a Lifetime folding table and longer hoses to get as far away from the trailer as possible.
Dobbs is offline   Reply With Quote
Old 02-01-2022, 03:05 PM   #8
"Don't Tread on Me"
sgtsdj's Avatar
Dobb’s
Where did you get your LP hose extensions?
Steve J.
Retired VA Law Enforcement
, Good Sams Life Member
Rockwood Roo 235S
2002 F-250 7.3 Diesel Powerstroke Powerhouse
Chipped, Bank's Exhaus
t - "Bad to the Bone"
sgtsdj is offline   Reply With Quote
Old 02-01-2022, 09:28 PM   #9
justpassinthru's Avatar
Propane grill extension
Originally Posted by sgtsdj View Post
Dobb’s
Www.propanegear.com
justpassinthru is offline   Reply With Quote
Old 02-01-2022, 11:34 PM   #10
Dobbs from WI
Dobb’s
I got mine on Amazon in 2019.
DOZYANT 12 feet Low Pressure... https://www.amazon.com/dp/B06XK43NL3?ref=ppx_pop_mob_ap_share
Works well for me and it has a shut off at the griddle end.
Old 02-02-2022, 02:59 PM   #11
I was looking at the Blackstone grills also. I have a 2020 NOBO 19.1 28ft and that was before they included the side flip out propane grill. We do have the quick connect propane connection though right in that area.
What I want though is one that is BOTH Charcoal and Propane, or can be converted back and forth and I am not finding them in anything portable. I only see the combos like that on large outdoor pits.
I don't want to be tied specifically to propane and as an RVer I want something that can do many things in one unit. Used as a pit, smoker, fire box, and propane burner for morning coffee. I have intertained buying a portable pit and installing a burner into it or on that side since they do sell the burners seperate.
This was an idea I had.
This unit on Amazon coupled with a burner. I need it to fold up and slide into the side hatch which is 7ft deep to the other side of the trailer in the front under the bed.
This is called Charcoal King and folds up and should fit within the hatch. Just needs a burner added to it.
https://www.amazon.com/dp/B07BHJJ1T3...v_ov_lig_pi_dp
Burner add on:
https://www.amazon.com/dp/B071749XB4...v_ov_lig_pi_dp
Anybody have any thoughts or have done this?
stephensatt is offline   Reply With Quote
Old 02-02-2022, 04:05 PM   #12
Dobbs from WI
I forgot to add that if using the Blackstone 17" or 22" with that hose you'll need an adapter like this to replace the griddle regulator.
Hotop 1/4 Inch Low Pressure Quick... https://www.amazon.com/dp/B07XGKDBFD...p_mob_ap_share
door
