Originally Posted by Flybob
Not sure what you mean by portable dehumidifiers, but do not waste your money on the solid state ones. I did some experiments with them several years ago and they took out a very small amount of moisture ( ie 1-2oz in 24 hrs). I current use a 20pt compressor type in my TT when stored. I ran the drain through the floor so no emptying.
Ditto on the solid or crystal types. I use a Compressor type and set it in the shower with the bucket's hose adapter open. I then leave the gray tank's valve open so I don't have to empty the container all the time.
No more water runs out of the discharge than from an AC system but air inside is as dry as you set the control for.
I found that using a second air circulation fan helped make sure the dehumidifier was keeping ALL the air as dry as possible, even in the far end.
Not in a motor home but in a 27 foot travel trailer for 20 years. When I sold it the interior didn't have any signs of mildew, mold, or musty odor..
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
