Old 03-05-2015, 12:42 PM   #1
Wingdreamer's Avatar
Rear camera purchase help?
I just purchased a new F/R Vibe trailer, 31 foot, 268RKS. Very excited, but dont get it till May. Will be towing this trailer with a 2010 F150 supercab with a 6.5 foot box, so combined length will be in the 50-55 foot range?
I want to add a wireless rear camera that I can mount on the back of the trailer and leave on at all times while driving. This will help for lane changes as well as backing up etc.
Question is, there are a ton of different kits out there, anywhere from $50.00 to $400.00. As I have just paid for this trailer ( $$ broke ), wife is telling me to behave myself with any further spending.....
Has anyone found a great deal on a unit that does the job? I'd like wide angle (170 degree) so that I can see the lanes, and preferably a 7" screen. I've seen some ebay that look decent but I guess you never know till you try?
Wingdreamer is offline   Reply With Quote
Old 03-05-2015, 12:55 PM   #2
I'm facing the same issue. Ask wife to consider the pain and agony of a single, minor wreck. Just the possible increase in insurance premiums is enough to make me feel the nicer models. I want to dodge that bullet at all costs.
woozy is offline   Reply With Quote
Old 03-05-2015, 05:18 PM   #3
IchLiebeBier's Avatar
I once had a wireless camera on my popup, and the reception was horrible (and the distance wasn't that great). I also think my cell phone interfered with it. Plus, I'd go by a pawn shop and I'd see their security camera video in my screen.
I finally scrapped it and installed a wired camera. When I upgraded to a TT, I kept the wired camera. It takes putting a few long A/V cables under the camper body and under and into your truck, but it was worth it to me. I just connect the camper to the truck when I hook up the plug.
I don't know if there are good wireless cameras out there, but I'd bet you'd pay a lot more for a good one to get good reception at that distance. With the wired ones, you can get a camera, the monitor and all the cables you need for less than 75 dollars.
IchLiebeBier is offline   Reply With Quote
Old 03-05-2015, 05:55 PM   #4
cbvp's Avatar
I've got my Voyager WVOS511 mounted on my second 5er. I did add a 35' extension cable and an 80"antenna extension so the antenna is mounted on the front cap.
I wired it to be on whenever my taillights are on. Put mine on for reasons you listed but also to keep an eye on this when going down the road.
C.B.
cbvp is offline   Reply With Quote
Old 03-05-2015, 06:02 PM   #5
Old Timer
Also take a look at this thread: Backup Camera for Fifth Wheel
kentnjudy is offline   Reply With Quote
Old 03-06-2015, 01:09 PM   #6
redcloud1's Avatar
more trouble than they're worth
I went through trying to run backup cameras on one of our trailer a few years ago, spent more money than I should have on two or three different setups, and all of them only worked half of the time. I became of the conclusion that the cameras were not meant to be on full time and it would burn out the camera. we just bought a Windjammer 3008 and it is pre-wired for a rear view camera but it only comes on whenever the tail lights are on on the trailer. so I kind of feel like if it was on all the time it also would burn out the camera. This is just the experience that I had
redcloud1 is offline   Reply With Quote
Old 03-06-2015, 01:30 PM   #7
IlliniJoe's Avatar
Here is the camera that I purchased. It is a bit pricey, but the reviews were excellent. I also ordered the side cameras but have yet to install them.
http://www.rearviewsafety.com/produc...cigarette.html
Retired Army CW4 - "Waterborne"
2005 Chevy 2500 crew cab with Duramax/Allison
2014 Lacrosse 327RES
Days camped 2014 - 0, 2015 - 24
IlliniJoe is offline   Reply With Quote
Old 03-06-2015, 01:40 PM   #8
Flybob's Avatar
I used this one
Rear View Safety RVS-770613 Rear View Camera System RVS-770613
I used this
Carlon 1 in. x 25 ft. Flexible Electrical Non-Metallic Tubing-12008-025 - The Home Depot
held up by conduit clips to frame under TT. Makes install simple, camera excellent quality and no signal loss, Has the ability to add two more cameras, ( maybe one for hitching up).
When running cable add an extra pull string should you want to add additional wiring later such as backup lights etc.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 03-06-2015, 02:34 PM   #9
I have been using unit from 4UCam, may wish to check them. Used on 30 TT, moved up to fiver, used same camera mounted to rear bumper of fiver. Now have flicker on monitor however they have an extender for 50.00 or less I'm gonnna get. When asked about flicker they suggested the extender and they also have a wireless model guaranteed no flicker etc for $350.00 I think it was.
2008 Cardinal 30RK fiver.
2009 Chevrolet 2500HD DuroMax
2009- 42 days; 2010-40 days, 2011- 40 days. 2012- 30 days,
2013- 14 days, 2014- 21 days, 2015- 42 days
2016-17 days, 2017-zero days
Wanderer is offline   Reply With Quote
Old 03-06-2015, 09:49 PM   #10
Stormrider151's Avatar
I buy all my camera setups at www.tadibrothers.com. I've had good luck with them. You can get one of their already made systems or design your own. They have pretty much anything you need.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost (Best tv ever)
2018 F250 Lariat (ok but I miss my F150)
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 03-06-2015, 10:38 PM   #11
Our new camper came with one but found out it is just a mirror and everything is backwards. Careful what you get.
Silverback Iowan is offline   Reply With Quote
