07-10-2020, 09:56 AM
Replace window wall AC
My PaloMini has a window ac unit in the sidewall. It seems to be glued with super glue LOL. Refuses to budge to be replaced. Is there something special that needs to be done to get it out?
07-10-2020, 10:23 AM
A Sawzall? [emoji38]
(Sorry, can't help, but couldn't resist.)
TV: 2021 Ford F-150 4WD XLT Crew w/ 3.5L EB & HDPP, payload: 2,416#.
Camping nights: 2021, 52; 2022, 99; 2023, 88; 2024, TBD (Est: 80+)
07-10-2020, 10:29 AM
Originally Posted by chriscowles
a sawzall? [emoji38]
(sorry, can't help, but couldn't resist.)
07-10-2020, 11:03 AM
Nothing wrong with a Sawzall. Just buy a larger unit to fill the hole.
Bruce
07-10-2020, 12:55 PM
Retired Member
Oscillating head type saw.
07-10-2020, 01:01 PM
Did you remove the insides so it is just the shell in the wall? It is probably screwed into the wall
Almost not an SOB
Artic Fox 3018 5th Wheel - on order
Grand Design 2800BH TT 2021
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2024 F350 DRW - on order
TV 2017 F150 6.5' bed 3.5 Eco-boost Max tow 1800lbs payload
07-10-2020, 10:11 PM
I tried and gave up
I had a Palomini 142sk with the window AC. I gave up trying to remove the unit.
According to Palomini tech support they use Proflex to bond the sleeve to the AC. I purchased and made tools in attempt to get beyond the adhesion but gave up when I started to make holes in the bottom of the sleeve.
All I was attempting to do was install a compressor start assist Super Boost to be able to run the AC from a 1000 watt inverter generator.
07-14-2020, 09:10 PM
Originally Posted by nomad297
nothing wrong with a sawzall. Just buy a larger unit to fill the hole.
Bruce
07-14-2020, 09:11 PM
Couldn’t budge the unit to attempt to remove the inside
07-14-2020, 09:12 PM
Wow. Right. It’s like it’s glued stapled and screwed in. Couldn’t get anywhere trying to remove and replace it
07-14-2020, 11:11 PM
What do they expect you to do if the AC fails and requires replacement?
