The stereo that came with my camper is terrible. The amp built into it was terrible. It had aux in and we used it for the TV, I use a raspberryPi in the camper as a HTPC, a computer monitor as the monitor, and the stereo as the sound source for movies and such from the RaspberryPi.
Anyways, stereo was terrible. If you turned it all the way up it barely got loud enough to hear dialogue. No less jam to some tunes on the outside speakers.
Removed. Here is the mess I'm dealing with.
Decided instead of trying to tap into that mess of wires, I'd cut the harness off the back of the old stereo and start from there.
I used a 12"x12" sheet of black lexan I bought on amazon to mount the new headunit to, to fill in the gap from the old stereo. Its easy to cut with a jigsaw, just go slow and take it easy.
New headunit mounted.
Its just the $20 one that walmart sells. All I really wanted was radio and aux in. This doesn't have a CD player, its just a receiver. But, I don't really own any CD's. Since it has bluetooth built in, I can connect to my phone and play Pandora or other music apps over it.
Here is the harness I cut off the old stereo, and the harness for the new one.
I soldered them together and used heatshrink tubing.
a little electrical tape over the amp on line, since I'm not using that and don't want it to short.
Then just wrap it up in some tape, solder joints can crack if they move around a lot, so you don't want them vibrating a bunch of anything.
Test fit.
Had to do some cutting to make the new stereo fit, it was wider than the old one.
I got a little happy with the jig saw.
And installed.
Works fantastic! Gets loud enough to cause the stock speakers to distort pretty bad. That might be my next upgrade, to install some new 6" speakers.
