Don't have picture of my prior TT where I did install a set, but could I ask if your use is to 1) inform others around you that you are backing, or 2) illuminate during night landings at the CG? If the latter, the ovals you will find, even LED ones, aren't very useful at all unless you have a reverse camera as well. They simply do not illuminate much area at all. Lights with a "driving light" reflector and lens pattern will give you the best illumination for smallest cost on either your TT or TV. If budget is no matter, a nice LED light bar (like those used on desert runners) would hug up nicely under the trailer bumper, give you control of aim, and give great light!
