05-18-2020, 09:52 AM
Roadmaster Comfort control shocks
Added the shock system to our 321 Freedom Express this weekend. Directions were spot on and the system is really top notch. With all the right tools, the install really wasn’t too bad. I’ll give it a test ride later this week.
Dave & Jerrolyn
South Jersey
2016 Coachmen Freedom Express 321.
05-18-2020, 09:54 AM
Seeing how some trailers bounce going down the road when they pass, that's got to be a big improvement!
05-25-2020, 08:20 PM
I put them on our 42ft 5ver and what a difference. Worth every penny.
05-25-2020, 08:25 PM
How long have you had them on? How many miles? Was there a difference in towing or just everything inside getting bounced around.
Originally Posted by Trevor and Melissa
I put them on our 42ft 5ver and what a difference. Worth every penny. Attachment 229903
05-25-2020, 08:54 PM
I noticed several differences. The porpoising virtually went away, no more damaged bike racks, braking is better and no wandering down the highway and chucking is gone. Probably have about 450 miles since installed.
05-27-2020, 07:28 PM
Excellent idea sir....we did the same on a 40ft 5er last year.
2017 F350 Dually 6.7
2019.5 Hathaway
He who dies with the most tools, wins!
05-28-2020, 11:15 AM
I see one problem with those shock mounts. They are below the tire scrub line. So if you have a blowout you loose the shock/mount. Just know from building hot rods.
06-09-2020, 02:52 PM
Those shocks hang below the tire rim. If you get a blow out they will be destroyed. It might even pole vault the trailerby the looks of it.
06-09-2020, 02:53 PM
Those shocks extend beyond the tire rims. If you get a flat they will be destroyed.
Originally Posted by SilhouettePenny
06-09-2020, 03:04 PM
They only hang below the rim if the springs are below the axle tube. You're good when the spring pack is above the axle. Not all rv's are the same.
06-09-2020, 03:10 PM
Well those springs are below the axle tube and clearly below the rim. Whether or not all RVS are the same is moot in this case.
06-30-2020, 08:25 AM
Slight adjustment just for you.....
2019.5 Hathaway
07-01-2020, 09:33 AM
Is that still the same system?
07-01-2020, 10:11 AM
Different with dual shocks at each wheel. At least these are above the scrub line!
