Originally Posted by 5picker
I often wonder if those that close off the skylight with something (especially black) realize the temperatures which then build up in the then sandwiched skylight area? Can't be good for that thin plastic.
While something inside could be removed, I've always liked the cover the outside with window tinting or some folks paint the "bubble" with a roof coating.
Wondered about the heat too. I put white vinyl tape over my skylight. And put a 1 inch piece of insulation up in the skylight and taped it in place with the same tape.
Not inexpensive tape but I had it already.
3M Venture White Vinyl Tape - 460V It holds up to moisture pretty well. I will find out how well it holds up to the elements. Couple of months so far.
Read previously someone painted their skylight white frost.
