Old 08-15-2022, 01:08 PM   #1
RV Skylight Insulator....you have options!
Was just looking around online and saw that those pillow style skylight insulators are like $30-40.
I got measuring. 14x22 for the skylight, 16x25 for a door window.
So I ordered a door window shade and velcro'd it on. Boom. No more hot arse bathroom and it only cost me $16 on Amazon. Easy to remove if I want.
2020 Ram 2500 Laramie Longhorn 6.4
2015 Flagstaff 27VRL
Riccochet is offline   Reply With Quote
Old 08-15-2022, 01:51 PM   #2
That's a great idea. Thanks for sharing.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 08-16-2022, 02:55 PM   #3
would you mind posting a link?
2021 Coachmen Spirit 1943RB
2013 GMC Yukon
Rolland is offline   Reply With Quote
Old 08-16-2022, 03:34 PM   #4
This is the one we bought.
https://www.amazon.com/dp/B08P2L9WHW...roduct_details
Old 08-16-2022, 03:59 PM   #5
I often wonder if those that close off the skylight with something (especially black) realize the temperatures which then build up in the then sandwiched skylight area? Can't be good for that thin plastic.
While something inside could be removed, I've always liked the cover the outside with window tinting or some folks paint the "bubble" with a roof coating.
Days Camped: '17=38 '18=49 '19=58 '20=110 '21=116 '22=95
Old 08-16-2022, 04:30 PM   #6
The back side of that panel is reflective. If the skylight allows UV and IR in, it will allow it back out.
I did check on the temp of it throughout the day. The black side you see in the photo was not even warm. Meaning it was reflecting all of the heat back out.
Old 08-20-2022, 12:00 PM   #7
Wondered about the heat too. I put white vinyl tape over my skylight. And put a 1 inch piece of insulation up in the skylight and taped it in place with the same tape.
Not inexpensive tape but I had it already. 3M Venture White Vinyl Tape - 460V It holds up to moisture pretty well. I will find out how well it holds up to the elements. Couple of months so far.
Read previously someone painted their skylight white frost.
2022 Rockwood 2511S
GolfingDave is offline   Reply With Quote
light, skylight
