Originally Posted by NINA
No photo's of the bike rack? Or was it just a
standard one that does not need explaination.
Nina
I have a Spare tire mount Bike rack. Pretty standard. What is not standard is the el cheapo pin/ubolts FR uses. Anyway...driving down the road, the bracket began to break the weld, and bend....bikes were almost laying flat. Anyways.....Had to heat the bracket, reshape it, then Drilled a 5 " 3/8" hole through the center of the bracket and through the bumper. Put a case hardened bolt there. Replace the pin with a case hardened bolt as well. Replaced the cast ubolts with stainless. Now it's strong and rigid and will not wiggle, bend, shake, vibrate........etc.
Got the jack installed, took like 10 minutes. Works like a champ. Will take photos this weekend while camping.
