Everyone has their own reasons for mods on their RVs.
Might not be right for someone else but what does it matter, it works for them and if someone else can use it, great.
Great job on your mod, looks clean and does the job for you.
Thanks for sharing!
You could take a noodle that is used in a swimming pool, cut it in the long direction in order to put the cables in it and then you just have a tiny hole to fill in order to keep critters out. Just a thought. Nice job.
2016 Forest River Wildcat 314BHX
2019 Ford F-450 Limited DRW 6.7 Diesel
Thats a good idea. I've got some 2" closed cell foam. I'll cut a tapered circle to fit the hole, drill a hole in the center for the wires, then make a cut from the outside edge to the hole. I can route the wires through that and then wedge it into my opening. Thanks for the suggestion!
