Old 09-02-2020, 10:40 AM   #1
Chardagha's Avatar
Sewer hose?
Gday!
I am tired of low quality sewer hose failure. Who can recommend the BEST brand/model sewer replacement hose available today? I am not brand conscious, I want quality. I want a hose that will stand up to repeated use. TIA
Chardagha is offline   Reply With Quote
Old 09-02-2020, 10:42 AM   #2
Just Tryin' to Help
cboss's Avatar
I've been using the same Rino hose for three years and lots of camping days.
Best RV Sewer Hose Reviews:
Thetford 1218.7853 Titan 15 Ft RV Sewer Hose Kit. ...
Valterra Viper 20 Ft RV Sewer Hose Kit. ...
Prest-O-Fit 1-0065 Blueline 25 Ft Ultimate Sewer Hose. ...
Camco RhinoFLEX Tote Tank Sewer Hose Kit. ...
Camco 20 Ft Durable High Tensile Strength Sewer Steel Wire Core. ...
Camco 20 Ft Sidewinder RV Sewer Hose Support.
Craig & Cath
2018 2902WS Rockwood Ultra Lite
2017 Ford F250 Lariat, 6.2 gas
Equalizer Hitch w/ 4-Point Sway Control
Days camped since 2016(retirement): 846
cboss is online now   Reply With Quote
Old 09-03-2020, 09:53 AM   #3
Retired Panpsychist
Theo's Avatar
We've been using the RhinoEXTREME hoses and they've held up really well!
The tough plastic coil ("exo-skeleton" as they call it) on the outside of the hose prevents the hose material from scraping on the ground while providing some crush protection. Last year I accidentally drove the truck over a section of the hose and it sprang back to shape. No leaks this year with the same hose!
Theo & Carol
2007 GoldenDoodle ("Cooper")
2020 Rockwood Roo 23IKSS
2015 F-150 4WD XLT SCab, 5.0L, 3.73, 36gal, HD Towing Pkg (53A), 1,980lb Payload
Theo is offline   Reply With Quote
Old 09-18-2020, 02:23 PM   #4
TomAR's Avatar
I switched out my system to WasteMaster as soon as I bought my rig; it reminds me of what professional chemical carriers use. Highly recommend; no regrets. https://store.lci1.com/waste-master-...or-359724.html
2018 Sunseeker 2400R MBS (w/dinette)
TomAR is offline   Reply With Quote
Old 09-19-2020, 08:00 AM   #5
Canadian Member
High End Hose: LCI Waste Master - but this one requires modification of your waste dump outlet.
The most popular good quality hose is probably the Camco RhinoFlex.
2019 Rockwood Signature 8290BS, Reese Revolution pinbox and B&W Patriot 18K hitch
Old 09-19-2020, 08:38 AM   #6
[QUOTE=cboss;2405055]I've been using the same Rino hose for three years and lots of camping days.
Ditto.
C.B.
cbvp is offline   Reply With Quote
Old 09-19-2020, 09:43 AM   #7
NXR
NXR's Avatar
I like the Valterra Dominator. It stays slinkyed up if you don't need the full length.
Where are you seeing the failures, at the coupling or pinholes along the hose? I use one of the Camco plastic angled sewer supports to keep the hose off the ground. I've seen many, many people who just lay them on the ground on rocks and sticks and I wonder if the slight movement of the hose plus the weight of the fluid when dumping causes the sewer hose to wear through against the rocks and stuff.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Ray
2020 Georgetown GT5 34H5
NXR is online now   Reply With Quote
Old 09-19-2020, 09:59 AM   #8
Jim34RL's Avatar
I have been using the Camco Rhino Flex hose for the last 4 years without any issues. Even the cheap hoses last at least three years for me. But I do not drag them on the ground or let them lay on the ground either. I also use the Camco sewer support to keep the sewer line off of the ground.
When they are put away I do not slide them in a bumper or tube either. I think sliding them over a rough metal edge can damage the sewer line when putting them in the bumper storage tube. When I had my first trailer with a bumper storage for the sewer line, I was replacing sewer lines every year. I store them in a Rubber made tote now.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 135K+miles
Old 09-19-2020, 01:00 PM   #9
like a couple have mentioned the waste master is the best . down side is you better have enough for all situations as getting extra lengths or fitting is not something you pick up at the local campground store are most other places . The rhino is what i use and it's not bad maybe 2 yrs per hose before it deteriorates , in full time use . weekenders i'm sure it will last many years
MR.M is offline   Reply With Quote
Old 09-19-2020, 08:42 PM   #10
Chardagha's Avatar
Thank you all for your suggestions. I would like the Wastemaster system most of all, but would have to make sure I had enough extension. Im thinking that I will go for the Camco Rhino Flex for now and watching to see how it goes. My problems were actual tears in the hose. Also, thanks for the thoughts about the bumper storage vs. tote storage.
Old 09-19-2020, 11:28 PM   #11
NXR
NXR's Avatar
I, too, looked closely at the Wastemaster and ultimately decided that its uniqueness and need to modify the RV was a non-starter. With standard hoses you can get parts and expertise literally anywhere. That was more important to me, being able to dump the tanks instead of waiting for parts to be delivered.
Ray
Old 09-20-2020, 09:09 AM   #12
Been using the same Rinoflex since 2007, bought a 2nd kit 3 years ago to extend (and get the new fangled swivel Fittings) and have the replacement for eventual failure. Still going strong.
Dale & Karen
2015 Lacrosse 311RLS
2006 F-250 The 06-6.0
Dwilcox is offline   Reply With Quote
Old 09-20-2020, 05:32 PM   #13
WFD
Been using the same Rhino Flex since 2012, no issues and still in great shape!
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 09-20-2020, 06:00 PM   #14
Our Rhino Flex is a 2012 vintage as well. Never an issue, still going strong.
2018 F 150 Supercrew 6.5 bed 3.5 EB Max Tow
Jfkmk is offline   Reply With Quote
Old 09-22-2020, 06:10 AM   #15
TomAR's Avatar
I thought long and hard before hacksawing off the twist-lock fitting so I could glue on the Wastemaster fitting. It was worth it!
Old 09-27-2020, 04:45 PM   #16
I've stored my RhinoFlex in my bumper for years without a problem. Just align it with the opening as you slide it in. The end fittings will fit in the bumper. You have to rotate them so the protrusions line up with the corners of the bumper.
- 2016 Ford F-150 SCrew Lariat 4x2 3.5L Ecoboost, 1700# payload
- 2020 Rockwood 2507S
chriscowles is online now   Reply With Quote
Old 09-27-2020, 09:11 PM   #17
I killed my RhinoFlex after only a few months. Have the extreme now, but hate the two 10 ft sections. I think the single 15ft hose length was perfect
2016 Dodge Durango 5.7L
2021 Coachmen Apex 288BHS
IvoryHemi is offline   Reply With Quote
Old 10-02-2020, 03:12 PM   #18
Chardagha's Avatar
Ray
Im careful in using my hose and do not generally leave it hooked up at a campsite until I need to dump. Ive had pinhole (and larger!) leaks along the hose, and I have difficulty attaching the sewer elbow to the raw coil end of my current hose.
