Originally Posted by Diesel Greg
Good idea but I’m 245lbs think it will work
I would think so. Believe mine are about four or five inches square so that reduces the pounds per square inch. Easy to maneuver into place and then tape down. Just so happened four high was a snug fit for me. Could always fill in a gap with thin plywood, masonite, etc.
No reason you could not put a couple of stacks in spread out since they are light(my reason to not use wood). With mine in the center I do not really feel any give in the area between the sides and the center.
I believe those were cut from the 2'x2'x1" boards most home supply stores sell. I still have a few pieces of other thickness behind my recliners waiting for use on other things. Left over from insulating my pass thru. Some pieces just made a good spacer for my new batteries when I moved them inside.
