12-26-2020, 02:45 PM
SimpliSafe Install
I just finished installing a SimpliSafe alarm system in our 22FBS/2205S and wanted to post a short description if anyone else is interested in doing something similar.
The biggest issue with installing a security system is the question of powering the base station with no shore power. In our case, the SimpliSafe system comes with a household, 110v power plug. But, if you look closely at the actual plug, you will see that the base station actually requires 6.5V DC.
In order to drop the standard 12V to 6.5 volts, I used a DC Buck Converter purchased from Amazon for $14.
This is powered by a small sealed battery that is charged by the Aux output of the solar controller. All of this is tucked away nicely in the cabinet under the fireplace. I didn't even have to drill any holes to run the wires since the controller is directly above this area!
The average draw on the battery is only .20A @ 6.5V, so it should last 5 days with absolutely no sun before the internal base station batteries kick in.
Let me know if you have any questions!
Cheers!
12-26-2020, 03:18 PM
What are you doing for an internet connection?
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
12-26-2020, 03:29 PM
Nothing. The Simplisafe system has its own cellular connection.
12-26-2020, 09:35 PM
I can see a monitored alarm for a fixed location but for one who moves around how does the monitoring station know which 911 dispatch center to notify if it receives notice of break-in or fire?
Do you have to "re-register" at each new address. Also, what about campgrounds with no address like when boondocking, and of course assuming they even have cell service?
12-27-2020, 08:01 PM
Very cool. When I look at their site I see you can spec different sensors but I didn’t see GPS, although the cellular portion may have it. If they do it could be used to help recovery if the rig is stollen, that could give a discount on insurance.
12-28-2020, 07:30 AM
We mainly got it for when we have her at the storage yard. We also placed a "do not dispatch" order on our account. So, if there is an issue, they call us and we will let them know if it's okay to call the PD.
12-28-2020, 07:33 AM
I don't think they have that type of capability. We mainly got it for peace of mind while it's at the storage yard.
If you are looking to track a stolen vehicle, I might suggest this: https://gpsandtrack.com/trailer-track-gps/
We use them at work and they perform very well!
05-03-2021, 12:34 PM
Thanks!
CivEngPE,
Thanks very much for your post. Exactly what I’ve been looking for. I’ll be trying to do a similar SimpliSafe install on our new ePro 19FBS (to be delivered in June we hope). I’m not an engineer but understand basic wiring, ac/dc, etc.
Working backwards, can you confirm:
1. SimpliSafe base station power input from 6v output on buck transformer
2. 12v buck transformer input connected into duracell 12v battery, can you tell me battery specs?
3. 12v Duracell connected to solar auxiliary output, can you describe where I should look for this, I hope mine has an aux output.
4. Do you need to keep trailer battery power disconnect switch on for this to work?
5. Could I also connect a SimpliCam the same way? The ac adapter on the simplicam says output is 5v 1.5a (I’m guessing that power draw would only be when the camera senses motion and starts and not a continuous power draw)
05-03-2021, 01:15 PM
Responses in-line below:
Originally Posted by Old Swede
CivEngPE,
Correct
Not quite sure. It's just a gel cell battery I picked up at batteries plus bulbs.
If you have the GoPower solar package, the 30A solar charge controller has an aux charge output. It will charge another battery other than the house battery. It was super simple for me since there is small cabinet right below my controller.
4. Do you need to keep trailer battery power disconnect switch on for this to work? Nope!
Probably, but I would opt for a bigger battery if you do this. Also, you will need two buck converters to make this work. There are several out there specifically designed to step down to 5v that might be a better option for that connection.
05-07-2021, 08:43 PM
Chief tinkerer
We installed a Simplisafe system for peace of mind, after we were broken into at the storage yard. Put sensors on the outside compartment doors and a motion detector inside. We found this listed on another site as a match for providing 12v power. Fused connection to coach batteries and 100 watts of solar has kept it happy for 4 years so far.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Gary
2017 SunSeeker 3010DS
