Old 07-02-2015, 08:48 AM   #21
Originally Posted by bob caldwell View Post
Can't remember how you attached your cover....I know how you made it and the materials and need something to do .
Just cleaned the area with acetone and taped it down with Eternabond.
Old 07-03-2015, 04:24 PM   #22
golfmedik's Avatar
Clean the skylight on the outside with soap and water, then let dry. Tape off the skylight and paint with 3-4 coats of Gloss White Krylon Paint. All the light comes in, no heat though.
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is offline   Reply With Quote
Old 07-03-2015, 06:57 PM   #23
Go to a store that sells baby clothes or a Walmart and buy a package of the stick on sun shades that people put in the car windows to shade the kids. They work great and they stick on in about 5 seconds and come right of when not needed. They really keep the heat out very well. I thought my wife was nut when she put it up but !!!!!
3greywolves is offline   Reply With Quote
Old 07-03-2015, 07:23 PM   #24
I was trying to keep the major portion of the sun off the bubble as it deteriorates too fast and becomes brittle and subject to breaking pretty easily.
Old 07-03-2015, 07:37 PM   #25
This is what we did to the skylight over our shower.
SkipnTerri is offline   Reply With Quote
Old 07-03-2015, 07:40 PM   #26
Sorry, can't get the pics to download. Took reflectix and velcroed it on four corners of the shower skylight.
Old 07-03-2015, 08:59 PM   #27
Left Coast
Turn the bubble over and use as a bird bath.
Old 07-04-2015, 09:10 AM   #28
Georgia Rally Coordinator
aceinspp's Avatar
If you use 303 Protectant the plastic cover will stay like new. It needs to be applied when you first buy your unit. Apply every 6 weeks. Works great and this is what the aircraft industry uses.
My new camper came with the sun shade which was nice.
Later RJD
2020 Shasta Phoenix SPF 27RKSS
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
Days camped 2020 49
Old 07-10-2015, 02:27 PM   #29
lgray's Avatar
golfmedik,
Great solution, used full can, 4 coats. I have reflectix on the interior, which no longer is warm to the touch. The paint & Reflectix is a 1-2 knock out punch for keeping the heat out. Paint is an aesthetically pleasing option to protect the skylight against the elements. Time will tell on durability, mine will be the true test, salt air and full sun, 24/7, 365 days a year.
ID:	82522   Click image for larger version
lgray is offline   Reply With Quote
Old 07-10-2015, 02:29 PM   #30
Left Coast
Worked for me also.
Old 07-10-2015, 10:21 PM   #31
skylight shade
Durability is my concern with the paint. Wandering if the sun would but it off and eventually look worse like it does on my deck. I made a shade from an old car privacy shade but here my concern is super heating the bubble. It gets very hot between the shade and the bubble. ?Definitely will use the 303, though.
I wonder if the body shop sprayed it and put the clear coat on, like on the coach body, if that would work.
AbdRahim is offline   Reply With Quote
Old 07-11-2015, 06:26 AM   #32
The only way to keep from super heating the bubble is to put a shield over the bubble instead of just painting it. Even the surface of white cars get hot.
light
